    ToolBoard 1LC fuse rating
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      Looking at the documentation for the toolboard it suggests putting and inline fuse which I would like to do, but do not know how to calc the required amperage.
      50w heater, 17HS10-0704S stepper with rated current/phase 0.7a
      Using this site https://www.electricalsafetyfirst.org.uk/watts-to-amps-calculator/
      I put 51w in to take account of the stepper and heater which then calculated 2.13a
      The smallest Blade fuse based on the above is 3amps.
      Is this safe or do I need to look at another solution, please.
      Regards
      Paul
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • fcwiltundefined
        fcwilt
        A 3 amp fuse should be fine but what voltage are you using for your calculations?
        • PaulHewundefined
          PaulHew
          24v Meanwell PSU. Was driving a Duet2 eth and a Duex
          • fcwiltundefined
            fcwilt @PaulHew
            @PaulHew said in ToolBoard 1LC fuse rating:
            Well the heater alone is going to need 2.08 amps. Add the current for the stepper and you could be up to 2.64 so a 3 amp fuse seems good - if it blows try the next size up.
            • oliofundefined
              oliof
              The tool distribution board uses 5A fuses.
              PaulHewundefined 1 Reply Last reply Reply Quote 1
              • PaulHewundefined
                PaulHew @oliof
                @oliof Morning, I was about to say, I do not have a tool distro board, but then saw the relevance of your reply!
                I have a selection anyway, but thanks for the info, good shout.
                I will start with a 3 and see what happens.
                Regards,
                Paul
                Paul
