    PT100 on Duet 3 6hc
    517
    • Nino Nobileundefined
      Nino Nobile
      Hello dears,
      a very basic question, is it possible to connect a pt100 temperature sensor on a duet 3 6hc board without using a temperature daughter boards?
      Thank you very much and greetings!
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Nino Nobile
        @Nino-Nobile no, hence why they sell daughterboards
          dc42 administrators @Nino Nobile
          @Nino-Nobile said in PT100 on Duet 3 6hc:
          Hello dears,
          It's possible, but the resolution and accuracy would be very poor.
          Nino Nobileundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti
            you can use a pt1000 without the daughter board.
            they work very well
              Nino Nobile @dc42
              @dc42 Thank you very much for your reply! Yes, I think it would have 1 ohm every 5ºC approximately, anyway I am interested in doing a test until deciding whether to buy a dougther board or maybe a pt1000. Is there information on what are the coefficients with which I must configure the firmware?
                Just get a Pt1000
                https://e3d-online.com/products/pt1000-temperature-sensor
                  Nino Nobile @Veti
                  @Veti Yes, the problema alredy buy a pt100 🤦
                    In that case, buy a daughterboard.
                    https://www.duet3d.com/PT100_DaughterBoard
                    • Vetiundefined
                      Veti
                      you can get a pt1000 sensor for around 4 euros.
                        Nino Nobile
                        Okok I understand the point, I think it will be easier and faster to get a pt1000 than a dougther board (I'm in Argentina). Thank you very much to all!
                        • Vetiundefined
                          Veti
                          there is a e3d reseller in argentina.
                          https://www.printalot.com.ar/
                          you can see if they sell
                          https://e3d-online.com/products/pt1000-temperature-sensor?_pos=1&_sid=1e8da88ec&_ss=r
                          its a bit more expensive, but if speed is the issue.
