    Need help with reprap 3 Gcode (extruder)
    1.2k
    • wingtipundefined
      wingtip
      Based on the link you posted Ive set up some temps for the hotend to select from the drop down but it isnt heating up and the temp shows 2000 all the time... might need to pull out the voltmeter to make sure its getting power but why would the thermistor show 2000 at all times?
      Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
        https://duet3d.dozuki.com/Wiki/FAQ#Section_My_temperature_shows_as_273c_or_2000c
        My temperature shows as -273c or 2000c
        A disconnected (open circuit) thermistor shows -273C in RRF. Other temperature sensor faults give a reading of 2000C, which triggers thermal protection as a safety. In general, check your wiring first and then ensure thermistor configuration is correct and uses the right syntax for your firmware version. i.e. RRF2 vs RRF3.
        What is your thermistor? Your config says it's connected to E1temp. Do you have it maybe connected to E0?
        @wingtip said in Need help with reprap 3 Gcode (extruder):
        so your saying that the only way to move the extruder stepper without heated hot end you have to use that console command every time you want to move it???
        Well normally you would be printing and would have it heated up.
        If you wanted to allow cold extrusion all the time you add the command to config.g so that it's run at startup. You can then remove it after you're done commissioning.
        You might also want to check out these macros which come in very handy on the PanelDue.
        https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF3/macros
        • wingtipundefined
          wingtip
          As mentioned in my first post its a e3d v6 with the stock included thermistor. The gcode for that thermister was copied from the dozuki list for rrp3 for the e3d v6
          I will check the wiring again.
          • wingtipundefined
            wingtip
            I checked for continuity from the connector at the thermistor through the breakout board, through the cat cable, through the next breakout board, and to the connector at the duet and it all checks out. As i powered the machine back up i noticed another error saying it was an unknown sensor... so i checked my gcode against the wiki again and im fairly certain i have it correct...
            My gcode:
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                        ; map heated bed to heater 0
            M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
            M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E1 temperature sensor
            M950 H1 C"e1heat" T2                           ; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
            From the E3D wiki:
            RepRapFirmware
            Edit the M305 P1 command in file sys/config.g on the SD card (you can do this in the web interface).
            • For firmware versions 1.16 and earlier, set the B parameter (beta value) to 4388. This value gives better accuracy at typical printing temperatures in the range 190 to 250C than the B value of 4267 quoted in the datasheet.
            • For firmware versions 1.17 and later, set the B parameter to 4725 and the C parameter to 7.06e-8.
            Restart the electronics to process the new config.g file.
            I am using the E1 heater slot and the Thermistor 2 slot on the Duet as you can see:
            http://puu.sh/HpWHZ/6701529966.jpg
              Yes that looks correct values for the E3D thermistor.
              Can you send M98 P"config.g" in the console and report the results?
              • wingtipundefined
                wingtip
                @Phaedrux said in Need help with reprap 3 Gcode (extruder):
                M98 P"config.g"
                  I think that should be M950 H1 C"e1heat" T1
                  Also, is there a reason you're starting with e1heat and e1temp instead of e0heat and e0temp?
                  • wingtipundefined
                    wingtip
                    really? i was going by this diagram which says for the e1 hotend the corresponding thermister is #2... but i can try your suggestion
                    • wingtipundefined
                      wingtip
                      E0 is my x motor, not the hotend
                        It's maybe a little confusing..
                        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M950_Create_heater_fan_spindle_or_GPIO_servo_pin
                        T Temperature sensor number, required only when creating a heater. See M308.
                        The T1 in the M950 command refers to the sensor you've created in M308 which is S1.
                        That's why it's giving the "error sensor number 2 has not been defined." Because it doesn't exist yet. ie been defined with an M308 command.
                        • wingtipundefined
                          wingtip
                          M98 P"config.g"
                          I think that solved it. i need to remove the hotend from the bmg so i can heat it up and tighten it down for the first time... then i will try to extrude and set the esteps for the extruder.
                            https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                            Might want to refer to this wiring diagram as well.
                            • wingtipundefined
                              wingtip
                              I have that one as well and it shows the same information, e1 is T2 but apparently is wrong as your suggestion to have me switch it to T1, in the gcode but still in the T2 slot, is working.
                              Have the hot end removed from the extruder and about to try to heat it up for the first time.... this thing is gettin close to being finished !!
                                It's the M308 that is creating the sensor. Sensor1 in this case. And it's using E1temp pins to do it.
                                M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                                Then M950 creates the heater. Heater1 in this case. And uses the e1heat pins to do it, then assigns sensor1 we just created to that heater with T1. T1=S1. The pins used are ancillary.
                                If you created another sensor and heater combo for a second extruder or something, it would use S2 and T2. And whatever pins you connected it to would be defined.
                                What I was asking before about using e1heat and e1temp was that it starts counting up from 0. So e0temp and e0heat are the first pins. It's not critical. It's just convention.
                                Hope that makes sense.
                                • wingtipundefined
                                  wingtip
                                  ehhh sort of lol.... this reprap stuff is new to me coming from marlin and that i just switched to reprap 3...
                                  right now the hot end is working great, thank you. However, the extruder will retract but will not extrude giving this error:
                                  Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                  This was with the hot end up to temp at 135c... so not sure why its saying not high enough...
                                    135 isn't hot enough.
                                    https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M302_Allow_cold_extrudes
                                    I think the default is 165 unless you've modified the minimum extrusion temp with the cold extrude command or have cold extrudes allowed explicitely.
                                    • wingtipundefined
                                      wingtip
                                      ummm i usually print my petg with 135 on my other printer... is 165 normal for a duet setup printing petg? Pla would be even lower...
                                      If i wanted to use this:
                                      M302 S120 R110 ; Allow extrusion starting from 120°C and retractions already from 110°C
                                      can i just put that anywhere in the heaters section of the config or must it be at a specific location?
                                        135 for PETG? 🤔 I think your old thermistor was bonkers.
                                        The heaters section sounds like a good place.
                                        wingtipundefined 1 Reply Last reply Reply Quote 0
                                        • wingtipundefined
                                          wingtip @Phaedrux
                                          @Phaedrux
                                          i dont know what i was thinking about the 135... its 235.... Getting old and trying to learn new "tricks" isnt goin well for me at times lol....
                                            Don't worry about it. I just wanna see the 3d printed james bond car so I'll help however I can. 😉
