    Tool head offset
    My Duet controlled machine
    • adhanabalundefined
      adhanabal
      Hi all
      I built a Multi head paste Extrusion machine using Duet wifi+ Duex5.
      I have given the tool offset and bed distance from end stops in the picture, when i print the head 1 and 2 are printing in the center of the bed , but 3 & 4 are not coming to the center, its printing on top corner of the bed. i have given the proper offset distance, pls see the config. What mistake im doing?!
      M208 X-55 Y-125 Z0 S1 ; set axis minima
      M208 X285 Y285 Z150 S0 ; set axis maxima
      M574 X1 Y1 Z1 S1 ; set active high endstops
      M563 P0 S"Head 1" D0 H1 F0 ; define tool 0
      M563 P1 S"Head 2" D1 H2 F1 ; define tool 1
      G10 P1 X66 Y-1 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 S"Head 3" D2 H2 F-1 ; define tool 2
      G10 P2 X0 Y-122.5 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 S"Head 4" D3 H2 F-1 ; define tool 2
      G10 P3 X-65 Y-122.5 Z0 ; set tool 2 axis offsets
      G10 P3 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      • timcurtis67undefined
        timcurtis67
        Shouldn't the X offset for Tool 4 be in the same direction as the X offset for tool 2? 2 is set to the positive direction and 4 is set to the negative.
        I believe all tool offsets are based from tool # 1. At least that is how I have mine set up.
        Also, did you try reversing the Y values on tool 3 an 4?
        adhanabalundefined 1 Reply Last reply Reply Quote 0
          adhanabal @timcurtis67
          @timcurtis67 Hi
          Thank you i have done the offset value correctly
