    FANS.... CONFUSION
    • mendeleviumundefined
      mendelevium
      I have two separate extruders, they are water-cooled so I do not need any cooling fans configured nor need any thermostatic control
      Hot end 0 has heater 0, Tool 0, Drive 0, heater 1 and Fan 0
      Hot end 1 has heater 1, Tool 1, Drive 1, heater 2 and Fan 1
      no thermostatically controlled fans
      in my config I have ....
      M563 P0 S"EXTRUDER 0" D0 H1 F0 ;TOOL 0 USES DRIVE 0 AND HEATER 1
      G10 P0 S0 R0 X-16.5 Y0 ; set tool 0 axis offsets
      M563 P1 S"EXTRUDER 1" D1 H2 F1 ; define tool 1
      G10 P1 S0 R0 X16.5 Y0 ; set tool 1 axis offsets
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      when I switch the machine, Fan 2 switches on (status at power on is switched on- I do not want this.
      What I want to achieve is that I have two different PART COOLER FANS which I want to run by command independently.
      Thanks for any help.... It complicated...
      • fcwiltundefined
        fcwilt @mendelevium
        @mendelevium
        On your second M106 P1 S1 that S1 specifies full speed - change it to S0 and the fan will be off at power on.
          mendelevium
          Many thanks...
          That sorted it.
