    Need help with Y axis re-design
    3D Printing General Chat
    513
    • reshundefined
      resh
      I picked up this printer knowing it needed some work. The prints are decent but I'd like to redo the rear part of this Y axis design. Looking for some ideas. I'm thinking about putting a dual shaft stepper inline of that rod and getting rid of the extra mini belt. I have a CNC and I'm planning on making the mounting plates out of aluminum. Thanks in advance
      • fcwiltundefined
        fcwilt
        Yes a dual shaft would work. Do you have a source?
        The other approach that is fairly common would be to install two steppers - I have two printers which do that.
        Do you think those 20x80 extrusions are big enough? 😉
        reshundefined 1 Reply Last reply Reply Quote 0
        • reshundefined
          resh @fcwilt
          @fcwilt thanks, Frederick. I normally buy everything from openbuilds.com but I don't think they offer the dual shaft. What are pros/cons to two Y steppers? It would actually be easier to do that setup now that you mention it. Yes, those 80's are pretty beefy!
          • fcwiltundefined
            fcwilt @resh
            @resh said in Need help with Y axis re-design:
            The only issue with dual steppers is keeping them in sync.
            For those using firmware v3 you can install a endstop sensor for each one. If the endstop sensors are carefully adjusted homing that axis will sync the steppers.
            I don't do that as I have found that once in sync they stay in sync. To put them in sync I turn off power and very slowly and carefully push them to the limit of the rails.
            • reshundefined
              resh
              Thoughts on needing a plate on the other (both) side of these idlers? The MDF is just a template but I'm thinking even when I cut it out of aluminum the weak point will be the long M5 bolts and the force of the tensioned belt putting everything in a bind. I can sandwich the idlers but it just means extending that 20x40. The back side is another story.
              mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt
                Whenever I can I support idlers on both sides.
                Here is a closeup of my MarkForged style printer showing one end of the right Y axis and the end of the X Axis belt where the idler is supported.
                Notice that I run the belt perpendicular to the rail which means I only need the 20 tooth pulley on the stepper and a 20 tooth idler at the other end.
                The holes in the "belt block" allow fastening whatever needs to be moved to the tapped holes in the rail carriage block.
                • mrehorstdmdundefined
                  mrehorstdmd @resh
                  @resh I second the idea of supporting both ends of the pulley axles. I used rectangular aluminum tubing in my printer to hold the pulleys. All you need is a hack saw and a drill press to cut and drill the aluminum.
                  UMMD corexy
                  corner pulley block
                  I also suggest you reconsider using those crappy little 3D printer idler pulleys. The bearings in them are almost microscopic and will not last. I suggest using stacked ball bearings for the pulleys. You can use much larger bearings that will last a long time. I used stacked F625 bearings in my sand table with 6mm belts. I used stacked F608 bearings for the 9mm wide belt in my corexy printer. You can put a twist in the belt to put the smooth side of it against the smooth pulley surface if you feel you must.
                  • reshundefined
                    resh
                    Thank you for these responses. I really like the idea of putting the belt perpendicular! @fcwilt did you fabricate that "belt block" or purchase? I have some 608 bearings on hand, didn't even think to use those.
                    • fcwiltundefined
                      fcwilt @resh
                      I designed and printed everything. The "belt block" is sized to fit the rail carriage block and the width of the belt.
                      In the picture the belts are 9mm.
                      I can send the files if you would like but I am traveling for the next couple of weeks.
                      • reshundefined
                        resh @fcwilt
                        @fcwilt When you get time I would appreciate it. Safe travels
