    always on fan not working ( 0.2V )
    620
    • micheldb14undefined
      micheldb14 @Phaedrux
      @phaedrux
      Here you can see I only have 0.3V right now on the 5V connector
      Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @micheldb14
        @micheldb14 And that's measuring fan2 header, correct?
        What do you get on the 5v pin of the jumper block itself?
        micheldb14undefined 2 Replies Last reply Reply Quote 0
          @phaedrux
          Yes, the 2 wires are connected to the FAN2 pins as shown in the 3rd picture
            droftarts administrators @micheldb14
            @micheldb14 You are measuring FAN2. That's a PWM fan, not an always on fan.
            micheldb14undefined 1 Reply Last reply Reply Quote 1
              @phaedrux
              I think this is how to measure from the 3 pin connector right?
                micheldb14 @droftarts
                @droftarts
                oh man..... thanks! I thought FAN2 was the always on fan because it a had a seperate 5V/VIN switch...now it all makes sense...
                  @micheldb14 You are still measuring onto a PWM pin (yellow wire), ie it's turned off unless you've defined a fan on it in config.g and turned it on. MOSFETs that controls PWM are always on the negative (ground) side, because they need to be placed after the 'load'.
                  Edit: Glad you got it figured out!
                  micheldb14undefined 1 Reply Last reply Reply Quote 0
                    @droftarts
                    So just to clear things up.
                    There is one jumper just to switch between 5V and VIN on FAN2
                    And the other Jumper is to switch 5V and VIN for FAN1, FAN0 and ALWAYS-ON FAN?
                    If this is the case, is there a way to set FAN2 as extruder fan so it will turn on when the hotend gets hot? (what now is the case with FAN1)
                      @micheldb14 said in always on fan not working ( 0.2V ):
                      @droftarts
                      Yes, that is correct.
                      Post your config.g and response to M115, so we know how it’s currently set and what firmware you are on.
                        @droftarts
                        M115
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-05-19b2
                        config.g:
                        ; Configuration file for Duet Maestro (firmware version 3)
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 14 2020 22:20:39 GMT+0200 (Midden-Europese zomertijd)
                        M550 P"AM8-BLV" ; set printer name
                        M918 P1 E4 F2000000 ; configure direct-connect display
                        M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P0 S1 D2 ; physical drive 0 goes forwards in spreadcycle
                        M569 P1 S1 D2 ; physical drive 1 goes forwards in Stealthchop2 till about 150 mm/sec
                        M569 P2 S0 D2 ; physical drive 2 goes forwards in Stealthchop2
                        M569 P3 S1 D2 ; physical drive 3 goes forwards in spreadcycle
                        M92 X200.00 Y200.00 Z1600.00 E411.00 ; set steps per mm
                        M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                        M201 X1000.00 Y800.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                        M906 X1100 Y1100 Z1100 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X-25 Y-25 Z0 S1 ; set axis minima
                        M208 X215 Y215 Z250 S0 ; set axis maxima
                        M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin xstop
                        M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin ystop
                        M574 Z1 S1 P"!^zstop" ; configure active-high endstop for low end on Z via pin zstop
                        M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                        M557 X10:200 Y10:195 S20 ; define mesh grid
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                        M572 D0 S0.035 ; Set pressure advance
                        M501
                          This defines and sets Fan 1
                          Add this for Fan2:
                          M106 P2 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                          micheldb14undefined 1 Reply Last reply Reply Quote 2
                            @droftarts
                            Tested and its working!
                            Thanks a lot!
