    always on fan not working ( 0.2V )
    616
    • micheldb14undefined
      micheldb14 @alankilian
      @alankilian
      yeah all the leds (VIN, 5V and 3,3V) are on
      • alankilianundefined
        alankilian @micheldb14
        @micheldb14 I would say check the solder joints to see if they look poor.
        I can't think of a reason to have the 5 Volt LED on and not have 5 Volts at the fan voltage connector.
        Maybe @dc42 has an idea about +5 voltage routing.
          Can you post a photo of the board and close up of the fan headers?
          You're saying the 5v V_fan pin on the voltage selector block isn't providing 5v at all?
          micheldb14undefined 1 Reply Last reply Reply Quote 0
            micheldb14 @Phaedrux
            @phaedrux
            Here you can see I only have 0.3V right now on the 5V connector
            Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @micheldb14
              @micheldb14 And that's measuring fan2 header, correct?
              What do you get on the 5v pin of the jumper block itself?
              micheldb14undefined 2 Replies Last reply Reply Quote 0
                @phaedrux
                Yes, the 2 wires are connected to the FAN2 pins as shown in the 3rd picture
                  droftarts administrators @micheldb14
                  @micheldb14 You are measuring FAN2. That's a PWM fan, not an always on fan.
                  micheldb14undefined 1 Reply Last reply Reply Quote 1
                    @phaedrux
                    I think this is how to measure from the 3 pin connector right?
                      micheldb14 @droftarts
                      @droftarts
                      oh man..... thanks! I thought FAN2 was the always on fan because it a had a seperate 5V/VIN switch...now it all makes sense...
                        @micheldb14 You are still measuring onto a PWM pin (yellow wire), ie it's turned off unless you've defined a fan on it in config.g and turned it on. MOSFETs that controls PWM are always on the negative (ground) side, because they need to be placed after the 'load'.
                        Edit: Glad you got it figured out!
                          @droftarts
                          So just to clear things up.
                          There is one jumper just to switch between 5V and VIN on FAN2
                          And the other Jumper is to switch 5V and VIN for FAN1, FAN0 and ALWAYS-ON FAN?
                          If this is the case, is there a way to set FAN2 as extruder fan so it will turn on when the hotend gets hot? (what now is the case with FAN1)
                            @micheldb14 said in always on fan not working ( 0.2V ):
                            @droftarts
                            Yes, that is correct.
                            Post your config.g and response to M115, so we know how it’s currently set and what firmware you are on.
                              @droftarts
                              M115
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-05-19b2
                              config.g:
                              ; Configuration file for Duet Maestro (firmware version 3)
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 14 2020 22:20:39 GMT+0200 (Midden-Europese zomertijd)
                              M550 P"AM8-BLV" ; set printer name
                              M918 P1 E4 F2000000 ; configure direct-connect display
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P0 S1 D2 ; physical drive 0 goes forwards in spreadcycle
                              M569 P1 S1 D2 ; physical drive 1 goes forwards in Stealthchop2 till about 150 mm/sec
                              M569 P2 S0 D2 ; physical drive 2 goes forwards in Stealthchop2
                              M569 P3 S1 D2 ; physical drive 3 goes forwards in spreadcycle
                              M92 X200.00 Y200.00 Z1600.00 E411.00 ; set steps per mm
                              M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                              M201 X1000.00 Y800.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                              M906 X1100 Y1100 Z1100 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X-25 Y-25 Z0 S1 ; set axis minima
                              M208 X215 Y215 Z250 S0 ; set axis maxima
                              M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin xstop
                              M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin ystop
                              M574 Z1 S1 P"!^zstop" ; configure active-high endstop for low end on Z via pin zstop
                              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              M557 X10:200 Y10:195 S20 ; define mesh grid
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                              M572 D0 S0.035 ; Set pressure advance
                              M501
                                This defines and sets Fan 1
                                Add this for Fan2:
                                M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                M106 P2 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                                micheldb14undefined 1 Reply Last reply Reply Quote 2
                                  @droftarts
                                  Tested and its working!
                                  Thanks a lot!
