    bed sensor always in minus
    • joekoundefined
      joeko
      hello,
      i own a new duet wifi (with reprap3.2.2) and have a problem with the bed sensor. the temperatur is not 20 degres it shows -20 degres. when i move sensor pin to e1temp doesnt has an efekt. the sensor is basicly ok but why is the temperatur in minus ?
        Post your config.g
        What kind of thermistor is it?
        • joekoundefined
          joeko
          config
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 01 2021 16:06:06 GMT+0200 (Mitteleuropäische Sommerzeit)
          M80 ; Power an
          M550 P"X-Plus" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards
          M584 X0 Y1 Z2:4 E3 ; set drive mapping
          M92 X94.12 Y94.12 Z400.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E180.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X270 Y200 Z200 S0 ; set axis maxima
          M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"!zstop+!e1stop" ; configure active-high endstop for high end on Z via pin zstop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T10000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H1 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S285 ; set temperature limit for heater 1 to 285C
          M106 P1 S0 H1 T50 ; set fan 1 value. Thermostatic control is turned on
          the bed sensor is NTC 100K 1% 3950 B
          but i also connected an e3d hotend thermistor to the bed sensor. if the sensor connect to the bed sensor on the duet i get -20, if i connect to e1temp than 20 degres
          alankilianundefined 1 Reply Last reply Reply Quote 0
          • alankilianundefined
            alankilian @joeko
            @joeko said in bed sensor always in minus:
            This should be T100000 not T10000.
            joekoundefined 1 Reply Last reply Reply Quote 1
            • joekoundefined
              joeko @alankilian
              @alankilian said in bed sensor always in minus:
              yes 🙂
              this solved it. thx 🙂
