    Leveling the colorless bed,
    963
    • synergy41
      synergy41 last edited by
      Hello everyone,
      I did a leveling of my tray, I think all is well to pass because I did not have any error message.
      However I am wondering a question, I noticed by browsing the subject present here that everyone show beautiful color image, for my part there is nothing displayed,
      I attach you my file
      thank you to you,
      [c]RepRapFirmware height map file v2 generated at 2017-07-16 22:06, mean error -0.025, deviation 0.055
      xmin, xmax, ymin, ymax, radius, xspacing, yspacing, xnum, ynum
      -120.00, 120.10,- 120.00, 120.10, 130.00, 40.00, 40.00, 7, 7
      0, 0, -0.035, -0.087, -0.146, 0, 0
      0, 0.066, 0.017, -0.039, -0.069, -0.084, 0
      -0.065, 0.036, -0.026, -0.016, -0.011, -0.023, -0.043
      -0.165, 0.002, 0.015, 0.016, 0.035, 0.000, -0.013
      -0.195, -0.028, -0.008, 0.002, 0.026, -0.004, -0.039
      0, -0.065, -0.008, 0.015, 0.002, -0.052, 0
      0, 0, 0.035, 0.038, -0.014, 0, 0
      [/c]
      I LOVE MY DUET WIFI
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.4.1
      Cura 4.10
      • Jackal
        Jackal last edited by
        What version of firmware and Duet web control are you using?
        • synergy41
          I use this version
          RepRapFirmware for Duet WiFi version 1.19beta11
          Do you have an idea ?
          Thank you
          I LOVE MY DUET WIFI
          Cura 4.10
            Please upgrade to the 1.19 release at https://github.com/dc42/RepRapFirmware/releases.
            The height map should be displayed in the browser if you are run G29 from it. Alternatively, click on the down arrow next to the Auto Bed Compensation of Auto Delta Calibration button and select Show height map.
            • synergy41
              I'm already in 1.19.
              When I click on the tab it shows me the bed but it all black
              without any color.Here is my display
              I LOVE MY DUET WIFI
              Cura 4.10
                What output do you get in the GCode Console when you run G29?
                Are you running DuetWebControl 1.19 as well as firmware 1.19? Look on the Settings/General page to check the version numbers.
                • synergy41
                  Here is my version
                  Here is the message after the command G29, weird because it probe me well the bed
                  I LOVE MY DUET WIFI
                  Cura 4.10
                    If you have a G29 S1 command in config.g to load an existing height map, remove it - at least until you have generated a new height map. See the firmware 1.19 upgrade notes.
                    Otherwise, it sounds to me that there is a problem with your M577 command. I presume you have one in config.g. Try pasting that command into the command line in the GCode Console and send it, and see if an error message comes back. If there is no error message, run M577 with no parameters to check that a grid is defined, then G29 again.
                    • Dougal1957
                      Dougal1957 last edited by
                      DWC V1.15A with FW1.19B11 and WIFI 1.19 don't seem to match to be fair I would at least upgrade DWC to 1.19 as well?
                      • whosrdaddy
                        whosrdaddy last edited by
                        Hi synergy41 ,
                        I see from your screenshots that you are running 1.15a for the webpage.
                        You must upgrade DWC to 1.19 to see the Heightmap.
                        If you already upgraded DWC, then you need to restart your browser to activate the new web page.
                        • synergy41
                          Yes it was that
                          thank you
                          I LOVE MY DUET WIFI
                          Cura 4.10
