    strange behavior from the thermistor
    691
    • SIamundefined
      SIam
      in the last time i get sometimes error heater fault this looks like shown in this picture
      2021-04-08 09_23_47-hypercube.png This shows the heat up only without moving anything on the printer. if this problem start it is impossible to heat up the extruder BUT when i restart the printer (m999) then it works without any problem this is what i don't understand. This problem is not Permanent in the last view weeks i had this issue three times.
      It seems that this happens when the printer was for longer time in idle
      I am a little perplexed at the moment so far i know is it impossible to repair a thermistor or cable by a reset 😉
      3; Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 16:17:09 GMT+0100 (Mitteleuropäische Normalzeit)
      ;pwm auf ausgang 5
      ;M555 P2												; Marlin emulation
      G90                                                 ; send absolute coordinates...
      M83                                                 ; ...but relative extruder moves
      M550 P"hypercube"                                   ; set printer name
      M667 S1                                             ; select CoreXY mode
      M552 S1                                             ; enable network
      M586 P0 S1                                          ; enable HTTP
      M586 P1 S1                                          ; disable FTP
      M586 P2 S1                                          ; disable Telnet
      m554 P192.168.188.1                                 ;set gateway
      M569 P0 S0                                          ; physical drive 0 = X goes backwards
      M569 P1 S0                                          ; physical drive 1 = Y goes backwards
      M569 P2 S1                                          ; physical drive 2 = Z goes forwards
      M569 P3 S1                                          ; physical drive 3 = Z goes forwards
      M569 P4 S1                                          ; physical drive 4 = Z goes forwards
      M569 P5 S0                                          ; physical drive 5 =  nc
      M569 P6 S0                                          ; physical drive 6 =  orbiter direct
      M569 P7 S1                                          ; physical drive 7 = E0 goes forwards bmg bowden
      M569 P8 S1                                          ; physical drive 8 = nc
      M569 P9 S0                                          ; physical drive 9 = g5 flex
      M584 X0 Y1 Z2:3:4 E6                                ; set drive mapping orbiter
      M350 X16 Y16 Z16:16:16 E16 I1                          ; configure microstepping with interpolation
      M671 X-1:390:-1 Y44:182:324 S3 F1.0                    ; Leitspindeln links und rechts von der X-Achse
      M92 X80.43 Y80.43 Z797 E692 ;z790.6 E1175 ;E1420 ;E714 ;E2143 ;E2124 ;E1900 ;4246 ;2123                     ; set steps per mm G5 Flex 2145 ohne dda 782.40
      ;M92 X80 Y80 Z802.46 E4286
      ; G5 Flex
      ; jerk
      ;M566 X600.00 Y600.00 Z300.00 E300 ;E150         ; set maximum instantaneous speed changes (mm/min) x/y 600 original
      M566 X300.00 Y300.00 Z50.00 E300 ;E300 last z = 150 xy=600
      M203 X30000.00 Y30000.00 Z1200.00 E3600.00     ; set maximum speeds (mm/min)
      ;M201 X4000.00 Y4000.00 Z1000.00 E600 ;E120;E180.00          ; set accelerations (mm/s^2) x/y 2000 z 500 original
      M201 X1500.00 Y1500.00 Z200.00 e600 ;E600 last z= 250 xy=1000
      ;19.3.2021, 18:30:31	m201 e3000
      ;19.3.2021, 18:30:16	m566 e1500
      ;19.3.2021, 18:29:55	m572 d0 s0.07
      ; x/y Nema 17 42BYGHW811 2.5Amp 4800Torque
      ; Z Nema 17 Bipolar 1.8deg 65Ncm 2.1A 3.36V 17HS24-2104S
      ; E bondtech bowden Nema 17 Schrittmotor 1.7A 40Ncm 1.8 Deg
      M906 X2500.00 Y2500.00 Z2100.00 E500.00 I30       ; set motor currents
      ; g5 flex
      M913 X85 Y85 Z85 E100 ;E50  							;reduce stepperpower
      M84 S35                                              ; Disable motor idle current reduction
      M208 X-1 Y0 Z0 S1                                  ; set axis minima
      M208 X400 Y370 Z415 S0                              ; set axis maxima
      M574 X1 S1 P"xstop"                                 ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                 ; configure active-high endstop for low end on Y via pin ystop
      ;M574 Z0 P"nil"										; Z entstop frei geben
      m591 D0 P2 C"zstop" S1								; Z entstop als filament sensor aktivieren
      M950 J1 C"duex.e5stop" ; Jnn = Input pin number (RRF 3.01RC2 and later only)/ C"name" Pin name(s) and optional inversion status.
      M581 P1 T2 S1 R1 ; P1
      M558 P8 R1.5 C"^!zprobe.in+zprobe.mod" H5 F600 T12000 ;A3 S0.01;
      ;G31 P500 X0 Y0 Z-0.05; 2 ;Z-0.2 ;24                                 ; set Z probe trigger value, offset and trigger height
      G31 P500 X0 Y0 Z-0.075;-0.1; 2 ;Z-0.2 ;24                                 ; V6 mit HC2
      M557 X0:383 Y0:361 P7:7 ;S75                            ; define mesh grid
      ;https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings
      M308 S0 P"bedtemp" Y"thermistor" A"Heizbett" T100000 B3950 H12     ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                               ; create bed heater output on bedheat and map it to sensor 0
      M140 H0
      M143 H0 S115                                        ; set temperature limit for heater 0 to 100C
      M307 H0 B0 S1.00                                    ; disable bang-bang mode for the nozzle heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 H10 L-3;B4276       ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                ; create nozzle heater output on e0heat and map it to sensor 1
      M308 S2 P"mcu-temp" Y"mcu-temp" A"MCU"					  ; set virtual heater for MCU
      M143 H1 S290                                        ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                                    ; disable bang-bang mode for the nozzle heater and set PWM limit
      ;M950 F0 C"fan0" Q25500 ;H-1                              ; create fan 0 on pin fan0 and set its frequency
      ;M106 P0 S0 H-1 C"Bauteilkühlung"                                  ; set fan 0 value. Thermostatic control is turned on
      M950 F0 C"fan0" Q500;H-1                              ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q500 T45 ;H1                              ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45 C"Hotend"                                    ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q250 ;H-1                              ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1 F250 C"LED"                                  ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"Links" D0 H1 F0                               ; define tool 0              *****
      ;M563 P1 S"Rechts" D1 H1 F0                             ; define tool 1              *****
      G10 P0 X0 Y0 Z0                                    		; set tool 0 axis offsets
      ;G10 P1 X0 Y0 Z0                                     	; set tool 1 axis offsets
      G10 P0 R0 S0                                        	; set initial tool 0 active and standby temperatures to 0C
      ;G10 P1 R0 S0                                        	; set initial tool 1 active and standby temperatures to 0C
      M501                                                	; load saved parameters from non-volatile memory
      M911 S22.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" 	;auto save on loss of power
      M572 D0 S0.10;4											;Pressure advance
      m593 F35 												;Dynamic Acceleration Adjustment
      ;m592 D0 A0.0122865 B-0.001164296
      ;m592 D0 A0.003538564 B-6.21548E-05
      ;m592 D0 A0.000719029 B0.001242184 						; nonlinear extrusion
      ;M572 D0 s0.02											;extruder pressure advance
      T0                                                  	; select first tool
      ;M207 S4.0 F4800 z0.8									;Set retract length
      ;M290 S0.15 R0 ;
      ; config-override.g file generated in response to M500 at 2021-04-07 21:28
      ; Heater model parameters
      M307 H0 R0.133 C1354.300:1354.300 D0.50 S1.00 V24.3 B0
      M307 H1 R1.833 C322.931:213.622 D9.11 S1.00 V24.2 B0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      M486 S-1
      8.4.2021, 11:28:18	=== Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
      Used output buffers: 3 of 24 (20 max)
      Static ram: 23460
      Dynamic ram: 74348 of which 80 recycled
      Never used RAM 14192, free system stack 115 words
      Tasks: NETWORK(ready,185) HEAT(blocked,294) DUEX(blocked,31) MAIN(running,382) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK)
      Last reset 02:04:05 ago, cause: software
      Last software reset at 2021-04-08 09:24, reason: User, GCodes spinning, available RAM 14228, slot 0
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 29.3, current 40.0, max 40.5
      Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 15603, standstill, SG min/max 0/171
      Driver 1: position -15764, standstill, SG min/max 0/173
      Driver 2: position 8173, standstill, SG min/max 0/1023
      Driver 3: position 0, standstill, SG min/max 0/317
      Driver 4: position 0, standstill, SG min/max 0/1023
      Driver 5: position 0, standstill, SG min/max not available
      Driver 6: position 0, standstill, SG min/max 0/1023
      Driver 7: position 0, standstill, SG min/max not available
      Driver 8: position 0, standstill, SG min/max not available
      Driver 9: position 0, standstill, SG min/max not available
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-04-08 11:28:16
      Slowest loop: 136.93ms; fastest: 0.20ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 2.7ms, write time 45.2ms, max retries 0
      DMs created 83, maxWait 311257ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 2530, completed moves 2530, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 6], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.3
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 123.01ms; fastest: 0.00ms
      HTTP sessions: 4 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.25
      WiFi MAC address 2c:3a:e8:0b:06:33
      WiFi Vcc 3.44, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24376
      WiFi IP address 192.168.188.36
      WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      === Filament sensors ===
      Extruder 0 sensor: ok
      === DueX ===
      Read count 1, 0.01 reads/min
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      jens55undefined 1 Reply Last reply Reply Quote 0
      • jens55undefined
        jens55 @SIam
        @siam this kind of behaviour is a common failure mode for thermistors. Not necessarily the exact failure you are seeing but the rapidly changing temperature swings that are much faster than what the heated mass could reasonably swing if the supply current was stopped and restarted. I am specifically talking about the quick sharp excursion in temperature and not the slower overall temperature change.
        You would likely see a slow deterioration/worsening with time.
        Get yourself a new thermistor.
        SIamundefined 1 Reply Last reply Reply Quote 1
        • SIamundefined
          SIam @jens55
          in this case i will try a new one thanks for your assistance
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @SIam
            That was not the solution i have changed the Hotend and Thermistor after this i was able to print. Now i wanted to Start a new Print and i get always the error :
            8.4.2021, 20:50:50	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.1°C/sec
            8.4.2021, 20:50:16	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.3°C/sec
            8.4.2021, 20:49:39	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.4°C/sec
            8.4.2021, 20:47:28	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.4°C/sec
            8.4.2021, 20:45:07	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.2°C/sec
            8.4.2021, 20:44:19	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.3°C/sec
            8.4.2021, 20:43:30	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.3°C/sec
            8.4.2021, 20:42:49	Error: Heater 1 fault: temperature rising much more slowly than the expected 1.4°C/sec
            What surprises me is that the expected temperature is constantly different ? The next thing is that this errors occur the most times at the same Temperature, although the temperature continues to rise as you can see here in this Video.
            show video
            • jens55undefined
              jens55 @SIam
              @siam, did you run heater tuning after you changed the thermistor?
              Did you use the correct data points for your new thermistor (in case it was different from the previous version)
              SIamundefined jens55undefined 2 Replies Last reply Reply Quote 1
              • SIamundefined
                SIam @jens55
                @jens55 said in strange behavior from the thermistor:
                yes i have done
                The new thermistor is The same type as the old one
                • jens55undefined
                  jens55 @jens55
                  @jens55, ugh, that is one ugly temperature graph! The good thing is that you don't have the sharp spikes and drops you had before.
                  Go ahead and see what re-tuning the hot end will do for you.
                  jens55undefined SIamundefined 2 Replies Last reply Reply Quote 1
                  • jens55undefined
                    jens55 @jens55
                    Hmmmm .... how did the tuning process go? Anything unusual? If you just turn on the hot end and let it sit without printing, what does the temperature do ?
                    • SIamundefined
                      SIam @jens55
                      Retuning is running now and the hotend has reached 220 C° ....
                      Here the log info
                      8.4.2021, 21:48:51	Auto tuning heater 1 completed after 3 idle and 10 tuning cycles in 510 seconds. This heater needs the following M307 command:
                       M307 H1 R1.294 C288.4:230.7 D4.05 S1.00 V24.3
                      Send M500 to save this command in config-override.g
                      8.4.2021, 21:45:56	Auto tune starting phase 3, fan on
                      8.4.2021, 21:43:45	Auto tune starting phase 3, fan off
                      8.4.2021, 21:41:52	Auto tune starting phase 2, heater settling
                      8.4.2021, 21:40:25	Auto tune starting phase 1, heater on
                      8.4.2021, 21:40:20	M303 T0 S220
                      Auto tuning heater 1 using target temperature 220.0°C and PWM 1.00 - do not leave printer unattended
                      and here a picture of the process
                      and now it seems my printer will be kidding me i have save the settings and loaded with m501 and now i get this message:
                      8.4.2021, 21:50:23	M501
                      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 205C
                      • jens55undefined
                        jens55 @SIam
                        @siam, I believe the thermistor is working well but that something is messed up in the setup parameters. Unfortunately I do not know config files well enough to help but I am sure that before long somebody else will pop up with the answer.
                        The warning that you are getting is for the bed heater and not the nozzle heater. Maybe verify that the correct parameters ended up in the right file as it is odd to get a bed heat warning when you were messing with the nozzle temperature.
                        • SIamundefined
                          SIam @jens55
                          after the pid tuning i can reach 220 c° without error and the temperature is stable range 219.8 - 220.1 C°
                          • jens55undefined
                            jens55 @SIam
                            @siam, so everything is working now?
                            • SIamundefined
                              SIam @jens55
                              Ok your right is heater 0 not 1 😳
                              • SIamundefined
                                SIam @jens55
                                happy too early ....
                                The temperature goes now slowly down and is no longer highly regulated
                                and now heater error ....
                                8.4.2021, 22:15:17	Error: Heater 1 fault: temperature excursion exceeded 15.0°C (target 220.0°C, actual 203.9°C)
                                • jens55undefined
                                  jens55 @SIam
                                  @siam, dang, I thought we had it sorted 😞 Is it dropping while you are printing or just when it is sitting there? If it happens while you are printing then try without printing. Do you have the part cooling fan on maybe? try without the part cooling fan.
                                  I am really grasping at straws here and am quickly running out of things to try ......
                                  • SIamundefined
                                    SIam @jens55
                                    dang, I thought we had it sorted Is it dropping while you are printing or just when it is sitting there? If it happens while you are printing then try without printing.
                                    Until this evening i was able to print without problems but since a couple of hours is printing impossible. Because the printer reaches not the print temperature anymore
                                    part cooling is off
                                    that's my problem too !!
                                    • jens55undefined
                                      jens55 @SIam
                                      @siam, the only thing that is left is the possibility of an intermittent power connection to the heater. Either from flexing due to the printhead moving about or, if the power cables are interrupted anywhere for a connector, from a bad connector.
                                      Try disconnecting and re-installing all connectors (including the one on the Duet board). Bad connections can develop over time and produce a bit of resistance that in turn will reduce power delivered to the heating element.
                                      • SIamundefined
                                        SIam @jens55
                                        @jens55 it seems that i have found my work over the weekend .... in the hope of finding the fault
