    Macro to call heaight map based on bed temp
    Gcode meta commands
    495
    • OwenDundefined
      OwenD
      Someone asked for this so I thought I'd post it here.
      This version uses variables to make it easier to tweak without searching through the code.
      It therefore requires RRF3.3b2 or later
      The attached files
      LoadMap.g
      CreateMultiTempMaps.g
      ; LoadMap.g
      ; requires RRF 3.3b2 or later!
      ; called to load height map according to current bed temp
      ; Bed must be at target temp so use M116 before calling this macro
      ;height maps must be already created
      ; adjust file location and file name of height maps to suit your system
      ; adjust temps to suit your requirements.
      ; Remember M116 may not wait until bed is fully at temp so set these a few degrees lower than target temp in slicer
      ;TempTolerance value will be used in M116 to ensure bed is stable to within +/- this amount from target
      ; ********** Macro assumes bed heater is H0! ***************
      var HighTemp = 98
      var MediumTemp = 68
      var LowTemp = 48
      var HighTempMap = "0:/sys/heightmapHigh.csv"
      var MediumTempMap = "0:/sys/heightmapMedium.csv"
      var LowTempMap = "0:/sys/heightmapLow.csv"
      var ColdBedMap = "0:/sys/heightmapCold.csv"
      var ExitIfBedOff = false ; set to true if you don't want to load a height map if the bed is turned off
      var AbortIfErrorLevel = 1 ; abort process if error level check is equal to or greater than this.  1 = warning, 2 = error
      var TempTolerance = 1 ; temp must be within this value- will be set in M116
      ; Do not adjust under this line unless you know what you're doing
      if var.AbortIfErrorLevel < 1 || var.AbortIfErrorLevel > 2
      	echo "AbortIfErrorLevel value must be either 1 or 2"
      	abort
      echo "Waiting for bed temp to stabilise"
      M116 H0 S{var.TempTolerance}; wait for any temp changes on bed to be within X degrees of target
      if move.axes[0].homed !=true || move.axes[1].homed !=true || move.axes[2].homed !=true
      	echo "Machine not homed - height map operation cancelled"
      	abort ; cancel macro & print
      G29 S2 ; Clear current height map
      if {var.ExitIfBedOff == true} && {heat.heaters[0].state == "off"}
      	echo "Bed is off.  No height map required"
      	M99 ; exiting macro but not cancelling print
      ;now check temps and load the height map to suit
      if heat.heaters[0].current >= var.HighTemp
      	G29 S1 P{var.HighTempMap} ; if temp is 100 or greater load this file
      	if result >= var.AbortIfErrorLevel
      		echo "Failed to load height map " ^  {move.compensation.file}
      		abort ; cancel macro and print
      elif heat.heaters[0].current >= var.MediumTemp ; if temp is less than 100 AND greater then  or equal to 70 load this file
      	G29 S1 P{var.MediumTempMap}
      elif heat.heaters[0].current >= var.LowTemp ; if temp is less than 70 AND greater then  or equal to 50 load this file
      	G29 S1 P{var.LowTempMap}
      		; START COLD BED MAP
      else ;      - temp is under 50 , so we might have a cold bed height map - otherwise delete COLD BED MAP section
      	G29 S1 P{var.ColdBedMap} ;
      ;END COLD BED MAP
      ; START FINAL CHECK
      ;do a final check and report height map loaded ; comment this out if you want no height map when under 50 degrees
      if move.compensation.file !=null
      	echo "Height map loaded is  " ^  {move.compensation.file}
      else
      	"MACRO ERROR: No heightmap has been loaded"
      	abort ; cancel print
      ; END FINAL CHECK
      ;if you don't use FINAL CHECK section, uncomment this line
      ;echo "Height map loaded is  " ^  {move.compensation.file}
      This macro will create all the height maps in the 0:/sys folder so that they can be viewed in DWC and loaded via the above macro
      ;CreateMultiTempMaps.g
      ; used to create multiple height maps based on varying bed temps
      ; adjust file locations as required.  Must be same in LoadMap.g
      M291 P"This process cannot be manually stopped.  Do not leave unattended.  Ready to begin?" R"Notice" S3
      var AmbientTemp = 36 ; bed must be below this value to be considered "Cold"
      var HighTemp = 100
      var MediumTemp = 70
      var LowTemp = 50
      var SoakTime = 180 ; time in seconds to wait for temp to stabilise to allow for over shoot
      if heat.heaters[0].current > var.AmbientTemp
      	M140 S0 R0 ; set active and standby temps to zero
      	M140 S-276 ; turn off bed
      	M291 P"Waiting for bed to cool to ambient" R"Cold Map" S1 T3
      	while heat.heaters[0].current > var.AmbientTemp
      		echo "waiting for bed to reach ambient - Current = " ^ heat.heaters[0].current ^ " Ambient = " ^ var.AmbientTemp
      		G4 S10
      	echo "Homing"
      	M291 P"Homing required.  Please wait" R"Homing" S1 T3
      	G28 ; home all if required
      echo "Creating cold bed map"
      M291 P"Creating cold bed map" R"Cold Map" S1 T3
      G29 S0 ; create bed mesh
      if result !=0
      	abort "Failed to create height map"
      G29 S3 P{var.ColdBedMap} ; save mesh to separate file
      if result !=0
      G29 S2 ; clear height map
      echo "Heating for nextmap"
      M291 P"Heating for next map" R"Heating" S1 T3
      M190 R{var.LowTemp}
      echo "waiting for temp to stabilise"
      G4 S{var.SoakTime}
      echo "Creating low temp bed map"
      M291 P"Creating low temp bed map" R"Low Temp Map" S1 T3
      if result !=0
      G29 S3 P{var.LowTempMap}
      if result !=0
      M190 R{var.MediumTemp}
      G4 S{var.SoakTime}
      echo "Creating medium temp bed map"
      M291 P"Creating medium temp bed map" R"Medium Temp Map" S1 T3
      if result !=0
      G29 S3 P{var.MediumTempMap}
      if result !=0
      M190 R{var.HighTemp}
      G4 S{var.SoakTime}
      echo "Creating high temp bed map"
      M291 P"Creating high temp bed map" R"High Temp Map" S1 T3
      if result !=0
      G29 S3 P{var.HighTempMap}
      if result !=0
      	M140 S-273 ; turn off bed
      M291 P"Process complete" R"Done!" S1 T3
      hestiahuangundefined MikeSundefined o_lampeundefined 3 Replies Last reply Reply Quote 2
      • hestiahuangundefined
        hestiahuang @OwenD
        @owend said in Macro to call heaight map based on bed temp:
        MediumTempMap
        wah...looks great...thx for the sharing.
        • MikeSundefined
          MikeS @OwenD
          @owend thanks for sharing! Will use it!
          Edit: i found that you should check if result is greater than 1 (or equal to 2) for error handling because result=1 is set when a warning is raised. In my case it is raised because i set Z=0 whit a physical endstop triggered by the nozzle and the use a npn probe only for quad gantry leveling and bed mesh. I set it with G92 Zxx.xxx, i don't know if there's another gcode command to make rrd aware that the correct Z0 was set.
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @MikeS
            @mikes
            I have revised the code to allow you to set the result level that is allowed before an abort.
            I have also added a macro to create the height map files files
            MikeSundefined 1 Reply Last reply Reply Quote 0
            • o_lampeundefined
              o_lampe @OwenD
              NOTE: THE FORUM ADDS {1} INTO THE CODE ON SOME LINE BREAKS. DELETE THESE
              It's probably a good idea to add the files for download, too? That way we don't have to read every line with 'eagle eyes' 🙂
              (although this is a great learning exercise)
              Thank you
              Olaf
              OwenDundefined 2 Replies Last reply Reply Quote 0
              • OwenDundefined
                OwenD @o_lampe
                This post is deleted!
                • OwenDundefined
                  OwenD @o_lampe
                  @o_lampe said in Macro to call heaight map based on bed temp:
                  Thank you
                  Olaf
                  Done
                  • MikeSundefined
                    MikeS @OwenD
                    @owend thanks for implementing. I think it would be a good thing to create a repo for these type of macro on github, maybe semi-official from duet? Obviously with all the necessary warning an so on...
                      dc42 administrators @MikeS
                      As an alternative to using M116 to wait for the temperature to settle and then testing heat.heaters[0].current, you could test heat.heaters[0].active which will be the commanded temperature.
                      • OwenDundefined
                        OwenD @dc42
                        @dc42 said in Macro to call heaight map based on bed temp:
                        That is certainly true in the case of the Macro to load the height naps and it would mean you don't have to worry about whether M116 releases before reaching the target temperature.
                        ergo. It's a cleaner implementation using .active
                        I just figured if you get that much bed variation to need this in the first place then you're going to have to wait sometime.
