    Variable Enclosure Fans based on Temperature (no heater)
    CNC
    643
    • EducatingSavvasundefined
      EducatingSavvas
      Hiya - I'm trying to wire up a couple fans (intake and exhaust) into a CNC enclosure so they only turn on at particular internal temperature. They are a bit noisy so this is why I'm doing it.
      I defined the thermistor with:
      M308 S0 P"e0temp" Y"thermistor" A"Enlosure_Temp"
      M950 F0 C"fan1+fan2"
      M106 P0 T50 H0
      Is this something possible to do without creating a heater. Plus is it possible to refer to the onboard CPU temperature?
      Many thanks, Savvas
      Argoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • Argoundefined
        Argo @EducatingSavvas
        I would use daemon.g with that and conditional gcode. Already read through the Duet documentation about the topic?
        EducatingSavvasundefined 1 Reply Last reply Reply Quote 1
          jay_s_uk
          @educatingsavvas you can only set one pin per M950 command
          M950 F0 C"fan1"
          M950 F1 C"fan2"
          M106 P0 T50 H0
          M106 P1 T50 H0
          that should do, although don't forget to add the thermistor information to the M308 (at a minimum the T and B values)
            EducatingSavvas @Argo
            @argo it's been a little while since I played around with the conditional gcode but will give it a go when I next have time.
              EducatingSavvas @jay_s_uk
              @jay_s_uk I pulled out the thermistor from an old 3D printer so might not know the values for those. But will tinker on the weekend.
                Phaedrux Moderator @EducatingSavvas
                @educatingsavvas said in Variable Enclosure Fans based on Temperature (no heater):
                Yes it is.
                M308 S0 P"mcu-temp" Y"mcu-temp"
                  EducatingSavvas @Phaedrux
                  @phaedrux
                  I can confirm this works. My fans are still noisy when they do turn on, but they are on for small amounts of time.
                  M950 F0 C"Fan1"		;Intake
                  M106 P0 T36 H0	;
                  M950 F1 C"Fan2"		;Exhaust
                  M106 P1 T36 H0	;
                  Many thanks, Savvas
                    You might be able to experiment with the min/max speed settings as well as the PWM frequency to see if you can improve the sound.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_spindle_or_GPIO_servo_pin
