    what if Macros appeared in Console?
    Duet Web Control wishlist
    • r123undefined
      r123
      It seems strange to me that there's no mention of any of the activity generated by Macros in the Console. None whatsoever.
      How about if there were lines in the console like
      "13/04/2021, 20:42:43 Macro: reset probe"
      or
      "13/04/2021, 20:42:43 Macro:Dock and Wipe"
      oliofundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @r123
        @r123 Macros are usually called via direct interaction, what would you use the logging information for?
        For those Macros I need output from, I use M117 or M118, which allows even more granular messaging than just that a Macro was started. So if you need a message on your particular system whenever a Macro is called, you could just start with one of these.
        • o_lampeundefined
          o_lampe @r123
          @r123
          what @oliof said.
          Also keep in mind, that a message sent by M117 pops up only once per session, while echo "message text" is sent everytime the macro runs
          • oliofundefined
            oliof @o_lampe
            @o_lampe in my experience, the echos only get output after the macro finishes, while the M117 is shown immediately.
            r123undefined 1 Reply Last reply Reply Quote 0
            • r123undefined
              r123 @oliof
              @oliof I reckon logging directly run macros is so that you can look back and see that you did (or did not) run bed levelling before that 5 hour print. For example.
              When we type Gcodes directly they land in the console, so why not macro filenames?
              Look forward to experimenting with M117, M118 - and "echo" @o_lampe ! - this weekend.
              Thanks.
                Not a bad idea. Moved to the wishlist.
                • o_lampeundefined
                  o_lampe @Phaedrux
                  @phaedrux said in what if Macros appeared in Console?:
                  While we are talking about wishlist in macro-context:
                  I tested a few things in macros and from time to time I made syntax errors or typos in variable names.
                  A vague warning popped up in the console about these errors, not naming the macro they happened in.
                  Was it t#free.g, t#pre.g or t#post.g?
                  Happy searching...
