    Odd Issue
    • R3playundefined
      R3play
      So yesterday I was printing just fine.
      Today I modelled something with Fusion360, exported it to a STL and uploaded it to my printer.
      Started the print and noticed that my extruder wasn't extruding during the print, so I canceled it, re-sliced, uploaded and tried again.
      Again same issue.
      Turned off the printer, then back on and re-connected via my browser.
      Now when I want to open the Jobs list I get the following error:
      I then removed the SD card and plugged it in the PC to check if it was corrupted or so. But nothing. Just worked fine.
      Re-installed it in the Duet board and still the same issue.
      Odd thing is, when I had the SD card in my PC I manually uploaded the gcode to it.
      Paneldue display is seeing all my files and can start the print (prints normally)
      However in web control I can't acces the file list.
      What's going on here?
      • R3playundefined
        R3play
        Edit: I can upload a file via web control, however it doesn't show up in there. Get the same error then.
        However, when I browse through my files on the paneldue, it is listed on there
          Can you copy and paste the full text from M122 and get the DWC version as well?
          After uploading via web control can you refresh the file list page?
          R3playundefined 1 Reply Last reply Reply Quote 0
          • R3playundefined
            R3play @Phaedrux
            @phaedrux said in Odd Issue:
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-9T6BU-FG3SN-6JKDD-3SN6S-TVWHH
            Used output buffers: 3 of 24 (24 max)
            Static ram: 23460
            Dynamic ram: 73344 of which 40 recycled
            Never used RAM 15236, free system stack 189 words
            Tasks: NETWORK(ready,188) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
            Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
            Last reset 00:00:40 ago, cause: power up
            Last software reset at 2021-04-14 18:47, reason: User, GCodes spinning, available RAM 15200, slot 1
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU temperature: min 19.5, current 23.8, max 24.0
            Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2021-04-15 17:03:37
            Cache data hit count 48010034
            Slowest loop: 115.29ms; fastest: 0.21ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 1.2ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is ready with "M122 " in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 150.09ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address 84:f3:eb:42:b5:1a
            WiFi Vcc 3.42, reset reason Power up
            WiFi flash size 4194304, free heap 25760
            WiFi IP address 192.168.1.2
            WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            Duet Web Control 3.2.2
            When I refresh after uploading via web control I get the same error.
            It says that the upload is succesfull, but I see no files in the 'Jobs' menu.
              Do you have a new SD card to test with? Copy over your files from the existing card and see if it works better.
              If that doesn't help, try replacing your current /www folder with the contents of the DWC zip file.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
              • R3playundefined
                R3play @Phaedrux
                Used a Sandisk 16GB card and that seems to have solved the issue.
                I guess the unnamed/unbranded 4GB card went bad 🙂
