Adding Drivers + mpu temperature ?
Hi , It been some time since looked through the M commands to see what's been added since my last look at every command.
Reading about the M308 , you can add mpu-temp and the driver temps to the extra graph on the Duet 3 mini + ?
I've tried what it say about add the mcu-temp .
M308 S11 Y"mcu-temp"
Error: M308: Unknown sensor type name "mcutemp"I've tried M308 S12 Y"drivers" for the driver and just get a zero temp.
How or can I add them and now ?
try this M308 S11 P"mcu-temp" Y"mcu-temp"
@peter247, sadly the MCU temperature is not available on the Duet 3 Mini because of a documented bug in the microcontroller. I will update the M308 documentation.
@dc42 The drivers should still output the temp warning flags though, right?
@phaedrux said in Adding Drivers + mpu temperature ?:
Yes.
