Solved Duet 2 wifi 3.2.2 bltouch homeall
Hi guys. so I have my maestro running just fine but older version
I finally got another duet for the similar printer
but having issues with home all it does x and y just fine but z G28 Failed to enable endstops
however if I hit home z it deploys probe and homes zhere's my config
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:05 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Duet" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z800.00 E101.06 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-5.5 Y0 Z0 S1 ; set axis minima
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 Z0 ; configure Z-probe endstop on Z; Z-Probe
M558 P9 C"^zprobe.in" H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X2.74 Y-3 Z2.051 ; set Z probe trigger value, offset and trigger height
M557 X0:305 Y0:315 S25 ; define mesh grid; Heaters
M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
M143 H0 S130 ; set temperature limit for heater 0 to 130C
M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 260C; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M591 D0 P2 C3 S1 ; Filament Run out sensor
G29 S1 ; Load mesh bed; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power losshomeall.g
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:06 GMT-0400 (Eastern Daylight Time)
G91 ; relative positioning
G1 H2 Z2.5 F6000 ; lift Z relative to current position
G1 H1 X-360.5 Y-355 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-360.5 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-405 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
G1 X220 Y175 F4000 ; Move probe to middle of bed
G30homez.g
; homez.g
; called to home the Z axis
G1 X0 Y60 F6000 ; go to first probe point
G30 ; home Z by probing the bed -
@ap742 said in Duet 2 wifi 3.2.2 bltouch homeall:
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)Remove those lines from homeall.g
@phaedrux You the man. Thank you good Sir!
