    duet 2 wifi 3.2.2 bltouch height map way off
    Firmware installation
    512
    • ap742undefined
      ap742
      hi guys. so upgraded. got most squared away I think.
      leveled bed with paper just like I did on old firmware but the map looks way way off
      M558
      Z Probe 0: type 9, input pin zprobe.in, output pin nil, dive height 2.5mm, probe speed 180mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
      bed preheated to 70c
      M I missing something ?
        If there some tilt in the print head or BLtouch mount such that it has a different trigger height depending on location?
        Where are you setting Z0 before running G29?
        Post your gcode files so we can see what's going on.
        ap742undefined 2 Replies Last reply Reply Quote 0
        • ap742undefined
          ap742 @Phaedrux
          @phaedrux I think I found my mistake . ended up tweaking my x and y and reducing probe number
          M557 X10:300 Y10:320 S50 ;M557 X0:305 Y0:315 S25 new and old
          & G31 P500 X-42.4 Y0 Z2.883 I hope its right
          after all that I ran G32 and each time adjusted each corner little by little .
          did first print not too bad I dont think its compensating as good as before .
          • ap742undefined
            ap742 @Phaedrux
            @phaedrux also my start g code
            M106 S0 ; turn off cooling fan
            G28
            G29 S1
            G92 E0 ; Reset Extruder
            G1 Z10.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
            G1 X344.5 Y300 Z0.28 F5000.0 ;Move to start position
            G1 X344.5 Y90.0 Z0.28 F1500.0 E15 ;Draw the first line
            G1 X344.7 Y90.0 Z0.28 F5000.0 ;Move to side a little
            G1 X344.7 Y300 Z0.28 F1500.0 E30 ;Draw the second line
            G92 E0 ; reset extrusion distance
            G1 Z15.0 F6000 ;Move the nozzle up 15mm
            G92 E0 ; Reset the extruder's origin
            M117
              Post your config.g, homeall.g and bed.g as well.
              • ap742undefined
                ap742
                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:05 GMT-0400 (Eastern Daylight Time)
                M550 P"DUET3D" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P3 S0 ; physical drive 3 goes backwards
                M92 X80.00 Y80.00 Z800.00 E391.455 ; set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
                M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X-5.5 Y0 Z0 S1 ; set axis minima
                M208 X350 Y350 Z400 S0 ; set axis maxima
                M574 Z0 ; configure Z-probe endstop on Z
                M558 P9 C"^zprobe.in" H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X-42.4 Y0 Z2.883 ; set Z probe trigger value, offset and trigger height
                M557 X10:300 Y10:320 S50 ;M557 X0:305 Y0:315 S25 ; define mesh grid
                ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
                ;M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0
                ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                ;M140 H0 ; map heated bed to heater 0
                ;M143 H0 S120 ; set temperature limit for heater 0 to 120C
                ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
                ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                ;M143 H1 S280 ; set temperature limit for heater 1 to 280C
                ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
                M143 H1 S300 ; set temperature limit for heater 1 to 300C
                M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                ; Custom settings
                M591 D0 P2 C3 S1 ; Filament Run out sensor
                G29 S1 ; Load mesh bed
                here's homeall
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:06 GMT-0400 (Eastern Daylight Time)
                G91 ; relative positioning
                G1 H2 Z2.5 F6000 ; lift Z relative to current position
                G1 H1 X-360.5 Y-355 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000 ; go back a few mm
                G1 H1 X-360.5 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G1 X140 Y160 F6000 ; go to first probe point
                G30
                & Bed
                G29 ; probe the bed and enable compensation
                  Phaedrux Moderator @ap742
                  @ap742 said in duet 2 wifi 3.2.2 bltouch height map way off:
                  ; Custom settings
                  Don't load the mesh in config.g. You haven't homed the printer yet.
                  This says the probe is 42mm to the left of the nozzle. Is that correct?
                  • ap742undefined
                    ap742 @Phaedrux
                    @phaedrux said in duet 2 wifi 3.2.2 bltouch height map way off:
                    so leave it out and let the slicer do it?
                    • ap742undefined
                      ap742 @Phaedrux
                      yes . its Hemera hotend . its exactly -42.4 on the left side of the nozzle I didn't know if I should round this
                      not my hot end but close enough
                        Yeah, you already have it in your slicer start gcode after the homing is done, so that's a good place for it.
                        The heightmap would indicate there is some tilt. Is that not the case? Some manual leveling should take care of that.
                        ap742undefined 1 Reply Last reply Reply Quote 0
                        • ap742undefined
                          ap742 @Phaedrux
                          Thank you so much for holding my hand.
