    BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
    Plugins for DWC and DSF
    27
    245
    40.2k
    • cosmowaveundefined
      cosmowave @MintyTrebor
      @mintytrebor
      I will try that in the evening...
      Some days ago, i have tried to install the plugin with RRF3.3b3.
      Was the same problem. So i think, something is wrong in my system or browser.
      I will clear the browser cache and history before installing the "new" set.
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        @mintytrebor
        after clearing browsers cache and history, re-installing the hole package, everithing is working fine!
        Thanks! 👍
        MintyTreborundefined 1 Reply Last reply Reply Quote 0
        • MintyTreborundefined
          MintyTrebor @cosmowave
          @cosmowave Great!. Glad you got it working 😁
          NodeDSF - Native Node-Red integration with Duet boards.
          BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
          ReleaseMgr - Duet update info inside DWC.
          Repo
          cosmowaveundefined 1 Reply Last reply Reply Quote 0
            @mintytrebor
            One question again...
            In the wiki is written:"Macro Name: (required) the file name of the macro in the default macro folder. Must end in .g eg Macroname.g"
            Is it only possible to call macros from the default folder? Or are subfolders from the macro folder also possible?
              @cosmowave Sub Folders should be possible (at least it was when I originally set up the feature - not checked since 😊 ). I think it should just be
              foldername/macroname.g
              Repo
                @mintytrebor
                perfect.
                I will try it. 👍
                  @cosmowave You should get a friendly error/warning if it is unable to find the Macro - but it does work with sub-folders I just gave it a quick try.
                  Repo
                    @mintytrebor very nice!
                    And thanks for this super usefull Plugin!! 🙌
                    If you have something like a wishlist: It will be nice to adjust the text size of object model buttons.
                    But that is not an important thing...
                      MintyTrebor
                      New update to v0.8.19
                      Updated Plugin for DWC 3.3 and added capability to change the font size of Object Model Panels.
                      Release is available here
                      Repo
                      cosmowaveundefined 1 Reply Last reply Reply Quote 1
                        @mintytrebor cool. Thanks for that!
                        Sometimes when i create a custom panel, the "hover text" is behind the panel itself... but no big problem...
                        • Diamondbackundefined
                          Diamondback
                          Wow! This is amazing, I hate that I didn't find this earlier! 🙂
                          I have an issue though, buttons within custom panels don't seem to do anything, they don't even trigger the "what happened last" text in the bottom bar. Normal buttons not within a custom panel work fine. Any idea?
                            MintyTrebor @Diamondback
                            @diamondback I think this may have something to do with the layer the button is displaying on.
                            Can you bring the panel to the top layer in layout mode, and re-test.
                            If that does not work ... have you enabled the "Enable Selections in Settings" switch in global settings?
                            Edit: It might also be worth trying to bring the button to the top layer in custom panel create mode
                            Repo
                            Diamondbackundefined 1 Reply Last reply Reply Quote 0
                              Diamondback @MintyTrebor
                              @mintytrebor Thanks for the quick answer! 🙂
                              Unfortunately none of that changed anything. I tried the setting you mentioned, no change (had it turned off before and didn't see any problem with radio buttons)
                              Bringing various elements to the top layer also had no effect, both in panel creation mode and the final tab mode.
                              Note: The button visually reacts to my click (ie the animations happen), it just doesn't execute anything.
                                @diamondback Can you see what happens if you change the button to a Gcode and use
                                M117 "Hello world"
                                as the command.
                                The reason for asking about the selects setting, is because there is an existing problem with some local installations which causes issues with layering/elevation in DWC. When you enable selects any drop down field renders the options behind the dialog window. I wanted to check if you had found another symptom of the same issue.
                                Edit: Also that macro path looks wrong to me see https://forum.duet3d.com/post/234267
                                Repo
                                • Nurgelrotundefined
                                  Nurgelrot
                                  Backup/restore button greyed out on 0.8.19. I've completely removed the plugin and reinstalled but the backup restore feature is un-selectable on one of my 2 installations... It worked one time to restore and then locked off.
                                    MintyTrebor @Nurgelrot
                                    @nurgelrot I'll have to do some tests, the button should only disable if the printer is busy (eg printing), or you are in layout or custom panel edit mode.
                                    Repo
                                    Nurgelrotundefined 1 Reply Last reply Reply Quote 0
                                      @mintytrebor Interesting, changing it to a gcode rather than macro makes it mostly work. It still doesn't show up in the footer bar, but it does actually execute the gcode.
                                      However, with macros still no luck in custom panels. (there is also nothing in the logs)
                                      The macro path is fine, mine do not have extensions. The button without custom panel that works, also has no extension in the path and works just fine. I also tried that very macro path in the custom panel button to no avail.
                                      This is the working button:
                                        @diamondback Thanks for the update. I will see if I can re-create the issue tomorrow.
                                        When I mentioned the Macro path, I was more concerned with the first '/' in your path. The default system Macro path is read from memory & should end with '/' (from memory - it was a while ago now 😊 ) - which means the combined path in your case would be '/default/Macro/Path//your/Macro/Path/macro'. The double '//' is what was concerning me. I am pleasantly surprised it works...
                                        Repo
                                          Diamondback
                                          @mintytrebor Oh, I see, I was just assuming it uses the same syntax as M98 🙂
                                            Nurgelrot @MintyTrebor
                                            @mintytrebor Something was off with my SBC on that host/printer got some permission errors when updating so I just redid the pi and the problem is gone. Prob not related to your plugin at all but thanks for taking a look.
