    BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
    Plugins for DWC and DSF
    27
    245
    40.0k
      jay_s_uk @cosmowave
      @cosmowave https://github.com/Duet3D/DuetWebControl/releases/download/v3.3.0/DuetWebControl-SD.zip
      cosmowaveundefined 1 Reply Last reply Reply Quote 1
      • cosmowaveundefined
        cosmowave @jay_s_uk
        @jay_s_uk Thank you very much for the link! 👍
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          cosmowave @MintyTrebor
          @mintytrebor I have deleted the www folder and then re-installed the dwc package.
          Then i was able to install the latest BtnCmd Version. But the problem with the info text behind the panels remains.
          For me, that is not a big problem. I will erase the info text of the buttons, because i do not really need them.
          Thanks for your help and time...
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            jay_s_uk @cosmowave
            @cosmowave very strange.
            Can you also try removing dwc-settings.json?
            it'll get recreated at boot
              cosmowave @jay_s_uk
              @jay_s_uk Deleting dwc-settings.json had also no effect. The hover-texts, and sometimes the blue edit buttons, are still behind the panels.
              I have deleted my hover texts. For me it's ok, when we close this problem...
                cosmowave
                Is it possible to move tabs in layout or custom panel mode?
                MintyTreborundefined 1 Reply Last reply Reply Quote 0
                • MintyTreborundefined
                  MintyTrebor @cosmowave
                  @cosmowave Use the clone tab feature - clone each tab in the order you want them to appear then delete the originals once you are happy.
                  I would take a backup first though 😀
                  Edit: Be careful with this approach if you use it to re-order custom panels, it creates a new custom panel ID, which is used to embed them in normal layout tabs.
                  Now I'm wondering if I added any checks to prevent a custom panel deletion if it is use in a layout.. One to put on my list I think.🤔
                  NodeDSF - Native Node-Red integration with Duet boards.
                  BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                  ReleaseMgr - Duet update info inside DWC.
                  Repo
                    MintyTrebor
                    I have updated BtnCmd for version DWC 3.4 b2 which can be found with the existing release for DWC 3.3.
                    Repo
                    • chimaeraghundefined
                      chimaeragh
                      @MintyTrebor Is there an option to save and export plugin configuration so that custom layouts can be deployed on multiple machines
                      Duet 2 Wifi, Ooznest Workbee CNC 1510
                        MintyTrebor @chimaeragh
                        @chimaeragh
                        https://github.com/MintyTrebor/BtnCmd/wiki/Backup-&-Restore
                        It gives you an option to name the backup file, you can then download/upload from the system folder through the existing DWC file browser interface.
                        Repo
                        chimaeraghundefined 1 Reply Last reply Reply Quote 1
                          chimaeragh @MintyTrebor
                          @mintytrebor Thanks
                            chimaeragh
                            I have used this plugin to create a simplified dashboard to control my CNC on a mobile phone as the default dashboard is too cluttered for me.
                            I would like to add movement buttons to another tab that I can set move distances like this
                            Any idea how this can be achieved?
                            MintyTreborundefined 1 Reply Last reply Reply Quote 1
                              @chimaeragh Possibly.... by using variables:
                              (https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Variables)
                              1. Define A global variable
                              2. Create a set of buttons that change the value of the global variable to a fixed value (0.01, 0.05 etc)
                              3. Add an object model panel to display the current value of the global variable (https://github.com/MintyTrebor/BtnCmd/wiki/Object-Model-Value-Panel)
                              4. Create a macro for each access movement (X+, Y- etc) using the global variable for the distance parameter.
                              5. Create macro buttons for each axis movement macro. (X+, X- etc)
                              Repo
                              chimaeraghundefined 1 Reply Last reply Reply Quote 2
                                @mintytrebor Thanks
                                • SamanthaJaneyCakeundefined
                                  SamanthaJaneyCake @MintyTrebor
                                  @mintytrebor I'm having the same installation error as stuartofmt. I tried installing A.0.8.20 on RRF 3.3 via the settings "upload system files" button but it just goes "upload complete" and doesn't bring up any instructions or similar.
                                  There's now a folder in Sys which has the .json.
                                    MintyTrebor @SamanthaJaneyCake
                                    @samanthajaneycake Do you see the plugin installation wizard? What config are you running? (Standalone Board or Board/DSF/SBC)?
                                    Repo
                                      MintyTrebor
                                      I have published 0.8.21 for DWC 3.3 & 3.4:
                                      Changes:
                                      • You can now choose to show/hide the DWC top panel when in the BtnCmd screen (Enable in Plugin Global Settings)
                                      • Added more standard DWC panels, including:
                                        • Movement
                                        • Baby Stepping
                                        • Tools
                                        • Job Control
                                        • Extrusion Control
                                        • Extrusion Factors
                                      Release Here:
                                      https://github.com/MintyTrebor/BtnCmd/releases/tag/Alpha_0.8.21
                                      Repo
                                      cosmowaveundefined 2 Replies Last reply Reply Quote 4
                                        @mintytrebor Cool! 👍
                                        Thanks for your work and this awesome PlugIn! ☺
                                          @mintytrebor Is it possible to include the temperature graph in the "standard DWC panels"? With adjustable size would be nice! 😊
                                            @cosmowave I'll have a look and push an update if I can include it.
                                            Repo
