    BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
    Plugins for DWC and DSF
    27
    245
    40.2k
    • MintyTreborundefined
      MintyTrebor @tristanryerparke
      @tristanryerparke I'm using a stand alone config on a duet2. That may account for the variance??
      In principle DWC is the same for both versions - however there maybe some differences in the way the machine model is retrieved in the backend.
      In the plugin I am not retrieving the model, I am using the one that is already resident in DWC, so I will have to do some digging to see what I can find out. Its unlikely to be a speedy process though.
      Update: I've just spotted this post https://forum.duet3d.com/post/227873, which seems related to this issue. Looks like its an SBC issue.....
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      • tristanryerparkeundefined
        tristanryerparke
        @MintyTrebor With the 3.3rc1 update globals are now displaying correctly in btncmd!
        Would it be possible to have a color option for the Object Model panel?
        Or a color switch based upon value like the z-probe status in DWC?
        Also, what about a secondary organization structure in which buttons and panels could be grouped? Kind of like this on the DWC dashboard:
        Just some suggestions, I'm really loving this plugin so far.
        Much simpler than my previous node-red dashboard setup.
        Thanks,
        T
        MintyTreborundefined 1 Reply Last reply Reply Quote 1
          @tristanryerparke Good news that the global variables are working for you now! I will have a look at setting the panel colour in the next release. Conditional colours & grouping I will have to look into.
          Repo
          • madeinta1wanundefined
            madeinta1wan
            HI @MintyTrebor ,
            Have you ever come across an error like this:
            Installation failed!
            InvalidOperationException in InstallPlugin: Cannot perform command because the plugin service is not started
            I was running 3.2.2 (this is all in SBC mode) and tried to install Alpha 0.8.17 which wouldn't work and so I upgraded DWC to 3.3.0-rc1 and then this error occurred.
            Just tried Alpha 0.8.16 in case and got the same error.
            Thanks-
            Nate
            MintyTreborundefined 1 Reply Last reply Reply Quote 0
              MintyTrebor @madeinta1wan
              @madeinta1wan see : https://forum.duet3d.com/post/219064
              You need to install/enable the plugin service.
              Repo
              madeinta1wanundefined 1 Reply Last reply Reply Quote 1
                madeinta1wan @MintyTrebor
                @mintytrebor 👍 👍 👍
                Thanks
                • MartinNYHCundefined
                  MartinNYHC
                  Very nice and useful. Thanks for your work!
                  With Firefox when adding a new button the select "Type" does not expand. With up/down buttons it is possible to change the field value.
                  And in addition may I place a feature request? 😉 Would be nice to have a button type to execute a command line script/command.
                    MintyTrebor @MartinNYHC
                    @martinnyhc That looks like you have this issue here https://forum.duet3d.com/topic/22403/weird-dwc-z-index-dialogue-issue/6
                    Its a localised issue, the solution is in the the thread I linked. You can either do the proper fix or go into BtnCmd global settings and disable selects, which will turn every drop down into radio buttons as a work around.
                    With your feature request can I assume you are running a DSF/SBC configuration?
                    Repo
                      MartinNYHC
                      Changed global setting and that's fine.
                      And yes.....SBC always because I like it 😉
                        MartinNYHC
                        Oh yes....I could use a custom GCODE and use the execoncommand plugin but for example I would like to change something in the current GCODE file. So at least I need to pass a variable for the filename.
                          @martinnyhc I'm not planning to do anything with SBC only plugin features until the plugin framework has been finalised, and does not require manual user steps to enable/get working. But I will add your request to the wish list. In the meantime you can always use another solution for running linux commands, triggered with a mqtt/http button in BtnCmd. Home Assistant & Node-Red spring to mind.
                          By way of a general update I will be publishing the following new functions on the next release (aiming for this weekend if testing goes ok).
                          Colour options & vertical/horizontal layout option for Model Value Panels
                          Create Custom Panels - Design a new panel layout then use within a normal layout. Useful for grouping layouts etc.
                          Also made a few small UI changes and the normal round of bug fixes etc.
                          Repo
                            MartinNYHC
                            Yeah, already thought about MQTT. Thanks!
                            • stuartofmtundefined
                              stuartofmt
                              DuetMonitor may be useful to some users of BtnCmd - so herewith a shameless plug ..
                              One of its capabilities is to send an email - independent of its monitoring function. The monitoring function can be disabled - at which point its an email sending program.
                              https://forum.duet3d.com/topic/23282/duetmonitor
                              cosmowaveundefined 1 Reply Last reply Reply Quote 1
                              • cosmowaveundefined
                                cosmowave @stuartofmt
                                I use a Duet2 Ethernet wit RRF 3.3rc3
                                When i try to install the plugin, it uploads the files. But then nothing happens!?
                                There is no new plugin the "built-in plugin" tab.
                                Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                                jay_s_ukundefined MintyTreborundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @cosmowave
                                  @cosmowave that's the wrong place. Look under machine specific for the other plugins tab
                                    cosmowave @jay_s_uk
                                    @jay_s_uk
                                    I have looked there. But there is also no plugin!
                                      MintyTrebor @cosmowave
                                      @cosmowave Did you see the plugin installation wizard?
                                      I have not installed 3.3rc3 yet, so I will have to do some tests once upgraded.
                                      Repo
                                      cosmowaveundefined 1 Reply Last reply Reply Quote 0
                                        cosmowave @MintyTrebor
                                        @mintytrebor
                                        No, there was no wizard.
                                        There was only the upload to the system files. Then nothing happens...
                                          @cosmowave The plugin installation wizard is a standard DWC feature, and not part of my plugin. It should of at least popped up and gave you an error message at the very minimum. This suggests something else is going wrong.
                                          I will test on 3.3rc3.
                                          Repo
                                            @cosmowave have just uninstalled my plugin - upgraded my Duet2 Ethernet from 3.3rc1 to rc3 (both firmware and DWC), rebooted, downloaded a new copy of BtnCmd_DWC3.3RC1_Alpha.0.8.18.zip from github releases, and installed it using upload system files.
                                            The plugin installation wizard popped up and the plugin installed fine.
                                            I think you have a local issue with your installation (you need to get the plugin installation wizard to popup when you upload the plugin).
                                            I would suggest downloading fresh copies & re-installing:
                                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/Duet2CombinedFirmware.bin
                                            AND
                                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWebControl-SD.zip
                                            Plus download a new copy of the plugin before trying to install.
                                            https://github.com/MintyTrebor/BtnCmd/releases/download/Alpha_0.8.18/BtnCmd_DWC3.3RC1_Alpha.0.8.18.zip
                                            Repo
                                            cosmowaveundefined 2 Replies Last reply Reply Quote 1
