    duet 2 wifi 3.2.2 hotend / thermistor - e3d hemera
    Firmware installation
    • ap742undefined
      ap742
      hi guys sorting through little things
      hotend next on the list . copied old thermister settings from maestro and totally didn't work
      so its ready like 5 c off .
      so I played with M308 S1 P"e0temp" Y"thermistor" T100000 B4138 and changed 4 to 9 (B9138) . got me right room temp reading but pid failed ( would not heat up fast enough staid at like 100 or so . but hotend reached pretty high temp ( hopefully not fried - do have spares )
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @ap742
        @ap742
        the thermistor settings for e3d is normally:
        M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8
        Thermistor parameters
        Have you tried this ?
        You can also calibrate your thermistor with the H and L option
        https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M308_Set_or_report_sensor_parameters
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        ap742undefined 1 Reply Last reply Reply Quote 1
        • ap742undefined
          ap742 @SIam
          @siam said in duet 2 wifi 3.2.2 hotend / thermistor - e3d hemera:
          tried B4725 C7..
          read through Calibrate with H & L but I'm newbie and dont really understand what exactly I need to do 😞
          • ap742undefined
            ap742
            however. I went ahead and replaced thermistor with identical one - one from e3d
            and that's fine.
            what I dont understand is - only thing thats changed is duet board and display
            old setup was fine .
