    Duet 2 wifi 3.2.2 runout sensor
    Filament Monitor
    • ap742undefined
      ap742
      was trying to use my Old
      M591 D0 P2 C3 S1 off duet maestro but didn't work
      I tried M591 d0 p2 c3
      but M591 D0 gets me extruder 0 has no filament sensor
        Since you're using RRF3 now you'll need to use the new syntax.
        See here: https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_RepRapFirmware_Num_3
        ap742undefined 1 Reply Last reply Reply Quote 0
        • ap742undefined
          ap742 @Phaedrux
          @phaedrux I tried
          M591 D0
          Simple filament sensor on pin e0stop, enabled, output high when no filament, filament present: no
          and still doesn't work 😞
            M591 P2 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop
            • ap742undefined
              ap742 @Phaedrux
              @phaedrux said in Duet 2 wifi 3.2.2 runout sensor:
              isn't M591 P2 C4 S1 D0 the same thing ?
              would I load it under in config.g under endstops or it doesn't matter ?
              I get msg as it's working
              M591 D0
              however filament present: no always there even if filament loaded
                Phaedrux Moderator @ap742
                @ap742 said in Duet 2 wifi 3.2.2 runout sensor:
                No, in RRF3 you need to specify the pin name you wish to use.
                And yes it could go in config.g under the endstops. Seems like a logical place to put it.
                Does that PCB come out of the switch? Does it have any labels for each of the wires? How did you determine which wire to connect to each pin of the endstop header?
                • ap742undefined
                  ap742 @Phaedrux
                  @phaedrux Figured it out . it was wiring . originally I had it plugged in backwords into duet and instead of getting all the way in there and flipping I flipped them at the switch and signal pin was bad so I just re terminated all 3 and did the M591D with switch in and out and get Filament yes and now .. woooohooooo
                  Thank You good Sir
