    Open/Start Greyed out; connecting Duet 2 WiFi...going crazy HELP
    • PCNoobNeedsMajorHelpundefined
      I don't know much about configuring or programming. all i want to do is connect my duet 2 wifi to my PC.
      • Copied a backup of the SD
      • Downloaded Yat
      • All drivers are up to date
      • Changed EOL Sequence to <LF>
      • 'WiFi Reported Error : No Known Networkd Foud
        WiFi Module is Ide' (over and over again forever)
      • Go to terminal tab and Opem/Start is greyed out
      everything is connected and im stuck and very frustrated.
      *Note: I dont understand GITHUB or how to use it
      **Is there someone i can call to walk me through this. i spent so much time and money into this upgrade for my printer and its turning into a disaster, im almost ready to just forget it. PLEASE HELP!
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @PCNoobNeedsMajorHelp
        @pcnoobneedsmajorhelp
        in YAT, send
        M552 S0
        wait a few seconds
        send M558 S"*"
        then M587 S"SSID" P"Password" replace with your info. both are case sensitive
        then M552 S1
        give it 10-20 secs and it should show an IP address
        PCNoobNeedsMajorHelpundefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @PCNoobNeedsMajorHelp
          @pcnoobneedsmajorhelp Are you following the guide here? https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
          PCNoobNeedsMajorHelpundefined 1 Reply Last reply Reply Quote 0
            PCNoobNeedsMajorHelp @jay_s_uk
            @jay_s_uk
            Yes. Step 4 and Main Bullet point (Blue) #4
              @jay_s_uk Disregard the last reply it was meant for the other responder.
              Ok. So. I did all that and got an IP Address and there is a solid Blue LED now on the WiFi receiver on the Duet Board. Thanks! we're getting somewhere. Now what? The Open/Start is still greyed out
                PCNoobNeedsMajorHelp @droftarts
                @droftarts
                  @pcnoobneedsmajorhelp said in Open/Start Greyed out; connecting Duet 2 WiFi...going crazy HELP:
                  Don't worry about that. That's just to connect to the Duet. You're getting lots of messages in the main window, so you are already connected. If you've got an IP address, you should be able to connect now with a browser. See https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s11
