    reversed the bl touch wires and blew something...
    • dakingofhearts2003undefined
      dakingofhearts2003
      I have a duet wifi and i was having trouble with my bl touch so i unplugged it and it was dark so i plugged the black and wire in reverse and i heard a pop. It will come on and show the green light, the fuses are good, but the usb will only make a sound when connected with vin power, with usb only it does nothing. My wifi module is also not working. I have tools nothing looks burned what should i be looking for ?
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        Go through this and see how far you can get. Take some photos of the board with everything disconnected and maybe we can spot a burnt component.
        @dakingofhearts2003 said in reversed the bl touch wires and blew something...:
        Which wires did you plug where exactly?
        dakingofhearts2003undefined 1 Reply Last reply Reply Quote 0
          dakingofhearts2003 @Phaedrux
          @phaedrux in the probe section i was trying to diagnose a bl touch not responding issue in the dark i figured i must have put the connector on in reverse because i heard a pop and then no more wifi or usb.
