    Fan isn´t working. g.code problem?
    303
    • duttiundefined
      dutti
      hey,
      Sadly my 2 fans aren´t working any ways. Also when connect to the always on fan pins, nothing happened.
      Fan 24v.
      M122 --> 24v
      Wired both ways to be sure.... DONE.
      Duet2 wifi.
      Maybe the jumpers are not correct?
      thanks a lot!
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 24 2021 23:46:28 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Z9.Hemera"                                  ; set printer name
      M669 K1                                            ; select CoreXY mode
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z100.00 E408.00                  ; set steps per mm
      M566 X4800.00 Y900.00 Z1800.00 E600.00             ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y6000.00 Z1800.00 E6000.00          ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z1500.00 E500.00            ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M208 X300 Y300 Z300 S0                             ; set axis maxima
      M574 X1 S1 P"!xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F600 T600                ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X2 Y2 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X10:290 Y10:290 S35                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S80                                        ; set temperature limit for heater 0 to 80C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S250                                       ; set temperature limit for heater 1 to 250C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      • SIamundefined
        SIam
        The jumper looks good have you checked the fuse (F2) ? if you connect 24V directly from Power supply does the fan(s) then work ?
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        duttiundefined 1 Reply Last reply Reply Quote 0
        • duttiundefined
          dutti @SIam
          @siam direct from power supply --> working
          Fuse .... hmm ok. How can I test it?
          I mean the board is completely new..
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @dutti
            @barbarossa-cologne ok then we know that the fan's are good! If you own multimeter then measure if the both contacts have 0 Ohm. Alternative look in to the Fuse the left and the right contact must be connected together if not then the fuse is blown
            • duttiundefined
              dutti @SIam
              @siam
              No multimeter here 😕
              The orange one looks fine( Under F3) , the black one with the ´´1´´ on top. Can´t take a look inside.
              • SIamundefined
                SIam @dutti
                @barbarossa-cologne we need the fuse with the 1 on the top, you can pull it out from the board maybe it's the easier to look inside
                • duttiundefined
                  dutti @SIam
                  I guess that doesn´t looks good?!
                  • SIamundefined
                    SIam @dutti
                    @barbarossa-cologne it's not good to see, but I will say this fuse is dead, so you need a new one with 1 Ampere, and before you change it, check all cables witch going to the fan ports is possible that you have a shortcut somewhere.
