    Z-Probe Constantly Triggered - Help!
    • Shanian79
      Shanian79 last edited by
      DuetWifi with latest stable release.
      Has been working fine, then between jobs the Z-probe is showing as triggered (1000), regardless of probe position. Using a BL Touch V3.
      • Replaced the BL Touch unit with a new one-did not solve.
      • I tried using other heater pins for servo wire, with updated config - did not solve
      • Re-installed firmware and DWC - did not solve
      • DWC shows probe triggered after reboot even when probe is unplugged.
      Any suggestions appreciated. Config settings are below.
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 21 2020 09:47:23 GMT-0600 (Central Standard Time)
      M550 P"Ender A" ; set printer name
      M575 P1 S1 B57600
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S1 ; physical drive 3 goes backwards
      M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X235 Y235 Z260 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-30 Y0 Z1.65 ; set Z probe trigger value, offset and trigger height
      M557 X40:215 Y40:195 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S350 ; set temperature limit for heater 1 to 300C
      M307 H1 R2.583 C137.6 D4.53 S1.00 V24.1 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"fan0" Q10 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q10 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q10 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F-1 ; define tool 0
      M501
      M591 D0 P5 C"e0_stop" R5:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 140%, 3mm comparison length, disabled
      engikeneer Phaedrux 2 Replies Last reply Reply Quote 0
      • engikeneer
        engikeneer @Shanian79 last edited by
        @shanian79 my M558 command for my BLtouch looks like this:
        M558 P9 C"^zprobe.in" H3 R0.1 F100 T2500 A10 S0.01
        Looks like you don't have the internal pullup resistor enabled (the '^' symbol). You also don't need the zprobe.mod pin specified for a BLtouch.
        Failing that, have you checked the signal wire (black/white) is connected correctly? White goes to the z_probe_in pin (circled red below), whilst black goes to ground (circled black). Double check both connections (including the crimps)
        i3 clone with a bunch of mods
          Phaedrux Moderator @Shanian79 last edited by
          @shanian79 said in Z-Probe Constantly Triggered - Help!:
          Remove the +zprobe.mod part.
          Add the pull up as @engikeneer says.
