Announcement: Duet 3 Toolboard revision v1.1
@khenderick adding one to the carriage should be sufficient
@khenderick said in Announcement: Duet 3 Toolboard revision v1.1:
Adding a Sammy C21 will be more realistic. Without highjacking the topic too much; having a toolchanger, would adding one to the toolhead make sense, so it would be used for / shared by multiple tools?
I suggest having one that you can move between tools. However, if all the tools are the same (e.g. all Hemera with standard hot end) then they should all have the same resonant frequencies, and you should only need to calibrate input shaping for one of them.
I write here not to open a new post.
Is it possible to connect an inductive probe (Omron TL-Q5 NPN ) powered at 24v to the IO_3in port of a 1LC v1.3 board?
How many voltage does the IO_3 port tolerate? -
@Gianluca please open a new post
