    Driver 3: short-to-ground
    My Duet controlled machine
    • Swannyundefined
      Swanny
      After period of perfect printing 1(4 months)with my toolchanger something strange occurs.
      Every time I try to print (with T0) a cylinder with a 5 mm hole in the middle it goes wrong in the first layer.
      But one a strange way. Starting gives no problem. The inner and outer wall (first layer) are printed perfectly.
      As soon as T0 starts to fill the rest I get a strange sound from the extruder and the warning “error: short-to-ground reported by driver(s) 3”.
      After searching on the internet I can only make the conclusion Duet board. Maybe you have another solution.
      M122.docx
        Can you post your config.g as well?
        Does T0 work otherwise?
        Can you test driver 3 with a different motor? And test the motor with a different driver?
        • Swannyundefined
          Swanny
          config.g.docx
          testing know a rectangle (box).
          first layer perfect
          second layer after a little part of that layer extruder starts to vibrate again with the same error.
          When I release the spring pressure for rhat extruder you can see it is not rotating any more but only vibrating.
            It sounds like the cabling for the extruder motor may be strained and having an intermittent connection after a bit of movement. Does the motor have a plug on the body or do the wires come straight out of the motor?
              One thing I notice in your config is that your jerk values for Z and E are incredibly slow.
              M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
              2mm/min is 0.03mm/s. this is even below the minimum default allowed of 0.1mm/sec.
              A more typical jerk value for extruder is 3000mm/min
                What Duet board is this? Can you provide the results of M122 and M98 "P"config.g" please?
