    Delta: flip X axis using software config
    • roboduetundefined
      roboduet
      Hello, is it possible to flip the X axis of a delta printer using the config without reconnecting the steppers and endstops? The print is mirrored and the things that should be on the right are printed on the left.
        droftarts administrators @roboduet
        @roboduet yes, you should be able to swap the stepper driver assignments of X and Y in M584. You will also need to swap the endstop assignments in M574, too, or the axes will use the wrong endstop.
        roboduetundefined 1 Reply Last reply Reply Quote 1
        • roboduetundefined
          roboduet @droftarts
          @droftarts Thanks, it works!
