    Hello Friends, I seem to have encountered an overshoot problem
    393
    • charlesundefined
      charles
      After the 20mm*20mm square was printed, it seemed that there was an overshoot problem, which caused the square of the square to not be straight. Which parameter should I modify for this problem?alt text
        dc42 administrators @charles
        What type of printer is it?
        charlesundefined 1 Reply Last reply Reply Quote 0
          Do you have pressure advance configured yet? Corner bulges can be tamed with pressure advance usually.
          • charlesundefined
            charles @dc42
            @dc42 My machine is Toolchanger
            • charlesundefined
              charles @Phaedrux
              @phaedrux I haven’t configured pressure advance yet. Will this situation have something to do with acceleration?
                Well yes, acceleration will play a part. So will jerk and overall print speed, but for the XYZ axis as well as extruder. It's all inter-related.
                https://duet3d.dozuki.com/Wiki/Pressure_advance
                Post your config.g and print settings if you want more detailed suggestions.
                • charlesundefined
                  charles @Phaedrux
                  @Phaedrux
                  Hello, Phaedrux, this is my config.g configuration file. I changed the comment file inside to Chinese.
                  My slicing software is cura3.4.1
                  config.g
                  The cura configuration is as follows:
                    What kind of a printer is it? E3D tool changer?
                    CoreXY tool changer, but what does it look like? Photo?
                    How heavy would you say the print head is with a tool loaded?
                    Direct drive or bowden extruder? A retraction distance of 7.5mm would indicate bowden. Have you tuned retraction yet?
                    Your max print speed is also quite low.
                    M203 X3000 Y3000
                    Only 50mm/s which is half the speed you've set for travel moves. So you should at least set your max speed to match what you want to use for travels. M203 X6000 Y6000
                    On first glance I would say your jerk values are a bit low, meaning the print head will slow down on corners, which can make bulges at corners more pronounced.
                    M566 X300 Y300
                    Try M566 X900 Y900
                    If you are using a Bowden extruder start with a pressure advance value of M572 D0 S1 and see how it goes.
