Duet 2 Wifi Board - Wifi not working
Hello everyone!
I've bought a Duet 2 Wifi board and I'm facing an issue which after googling and looking into this forum apparently ends up in a defective wifi module of my board. Been told to open this post for support so here it is.
It gives me the following error:
M552 S1 ok WiFi module started Error: Failed to initialise WiFi module: SPI timeout
And when I try to update the WifiServer it gives following error:
M21 M111 P14 S1 M997 S1 T:19.6 /0.0 T0:19.6 /0.0 B:19.9 /0.0 SDHC card mounted in slot 0, capacity 7.95Gb Debugging enabled for modules: WiFi(14) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16) CAN(17) T:19.4 /0.0 T0:19.4 /0.0 B:20.0 /0.0 Trying to connect at 230400 baud: failed Trying to connect at 115200 baud: failed Trying to connect at 74880 baud: failed Trying to connect at 9600 baud: failed Error: Installation failed due to comm write error ok
Thanks and regards.
@elpeter Please post your config.g and results of a M122
Do you have a panelDue connected as the second part of your post looks like it is looking for something that is not there.... Guess. -
@elpeter please connect via USB and send M552 S-1 to turn off WiFi, then M552 S0 to set it to idle. Then send M122, and post response. Then send M997 S1 to try the update again.
@paulhew said in Duet 2 Wifi Board - Wifi not working:
Do you have a panelDue connected as the second part of your post looks like it is looking for something that is not there.... Guess.There you go:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DLM-996RU-N85S4-7JKF2-3SD6S-1UAMP Used output buffers: 1 of 24 (14 max) === RTOS === Static ram: 23460 Dynamic ram: 73880 of which 60 recycled Never used RAM 14680, free system stack 174 words Tasks: NETWORK(ready,446) HEAT(blocked,306) DUEX(blocked,31) MAIN(running,409) IDLE(ready,20) Owned mutexes: USB(MAIN) === Platform === Last reset 01:13:20 ago, cause: power up Last software reset time unknown, reason: User, GCodes spinning, available RAM 14680, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 36.0, current 36.2, max 36.8 Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 1970-01-01 00:00:00 Cache data hit count 4294967295 Slowest loop: 5.11ms; fastest: 0.21ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.1ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.33ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 0 of 8 - WiFi - Network state is changingMode WiFi module is idle Failed messages: pending 0, notready 0, noresp 5 Failed to get WiFi status Socket states: 0 0 0 0 0 0 0 0 === DueX === Read count 0, 0.00 reads/min ok
It does have a PanelDue connected to it and working.
@droftarts said in Duet 2 Wifi Board - Wifi not working:
Already tried what you mentioned. That's what lead me to open the issue, as I've looked into this forum and other similar posts like mine got to that faulty wifi module conclusion...
Here's the output though:
M552 S-1 WiFi module stopped ok M552 S0 ok WiFi module started Error: Failed to initialise WiFi module: SPI timeout M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DLM-996RU-N85S4-7JKF2-3SD6S-1UAMP Used output buffers: 1 of 24 (14 max) === RTOS === Static ram: 23460 Dynamic ram: 73880 of which 60 recycled Never used RAM 14680, free system stack 174 words Tasks: NETWORK(ready,364) HEAT(blocked,306) DUEX(blocked,31) MAIN(running,408) IDLE(ready,20) Owned mutexes: USB(MAIN) === Platform === Last reset 01:15:18 ago, cause: power up Last software reset time unknown, reason: User, GCodes spinning, available RAM 14680, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 36.0, current 36.6, max 36.9 Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 1970-01-01 00:00:00 Cache data hit count 4294967295 Slowest loop: 100.19ms; fastest: 0.21ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.1ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 200.24ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 0 of 8 - WiFi - Network state is disabled WiFi module is disabled Failed messages: pending 0, notready 0, noresp 1 Socket states: 0 0 0 0 0 0 0 0 === DueX === Read count 0, 0.00 reads/min ok M997 S1 T:18.6 /0.0 T0:18.6 /0.0 B:19.1 /0.0 Trying to connect at 230400 baud: failed Trying to connect at 115200 baud: failed Trying to connect at 74880 baud: failed Trying to connect at 9600 baud: failed Error: Installation failed due to comm write error ok
Thanks all for your help!
Sorry, forgot to attach config.g. Here it is:
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Sixtina V-core 3" ; set printer name M669 K1 ; CoreXY G29 S1 ; Set Units to Millimeters ; Network M552 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; PanelDue M575 P1 S1 B57600 ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P3 S1 ; physical drive 2 goes forwards M569 P7 S0 ; physical drive 7 goes forwards M569 P8 S0 ; physical drive 8 goes forwards M569 P9 S0 ; physical drive 9 goes forwards M584 X0 Y1 Z7:8:9 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 ; set steps per mm M906 X1000 Y1000 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X10800.00 Y10800.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X510 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active high endstops M574 Y2 S1 P"ystop" ; configure active high endstops M574 Z1 S2 ; configure Z-probe endstop for low end on Z M671 X-4.5:250:304.5 Y-4.52:505:-4.52 S5 ; Define positions of Z leadscrews or bed levelling screws ; Z-Probe ;; Inductive Probe ; M558 P5 C"!io3.in" H5 F400 T5000 ; set Z probe type to unmodulated and the dive height + speeds ;; BL-touch ; M558 P5 C"io2.in" H5 F500 T10800 ; set Z probe type to unmodulated and the dive height + speeds ; Z-Probe M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-28 Y-13 Z4.582 ; set Z probe trigger value, offset and trigger height M557 X30:215 Y15:195 S20 ; define mesh grid ;M557 X30:300 Y15:300 P5 ; define mesh grid ; Heaters ; M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0 ; V-core Default ; M950 H0 C"out0" T0 ; create bed heater output on out5 and map it to sensor 0 ; V-core Default ; M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit ; V-core Default ; M140 H0 ; map heated bed to heater 0 ; V-core Default ; M143 H0 S110 ; set temperature limit for heater 0 to 110C ; V-core Default M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ;; Run Bed PID Tune!! Bellow is an example for a 300x300 bed M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ; V-core Default ; Fans ;M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency ; V-core Default ;M106 P0 C"Hotend Fan" S0 H1 T45 L255 ; set fan 0 name and value. Thermostatic control turned on for Hotend ; V-core Default ;M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency ; V-core Default ;M106 P1 C"Layer Fan" S0 H-1 L255 ; set fan 1 name and value. Thermostatic control is turned off ; V-core Default ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools ; M563 P0 D0 H1 F1 ; define tool 0 ; V-core Default ; G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets ; V-core Default ; G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; V-core Default M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1 ; V-core Default ; M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; V-core Default ; M143 H1 S250 ; V-core Default ; EVA 2 / BMG / E3D V6 M92 E415 ; set extruder steps per mm, 1.8 angle/step M906 E800 ; set extruder motor current (mA) and idle factor in per cent ; M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend" ; V-core Default ;; Run Heater PID Tune!! M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0 ; V-core Default ;G31 P500 X-30 Y-15 Z0.20 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ; V-core Default T0 ; Pressure Advance ; M572 D0 S0.10
Sorry for the mess, I'll clean it once I get it finally working...
@elpeter I can confirm that we consider this a warranty replacement issue. Please contact the reseller you bought it from, follow their warranty claim process, and quote this post as authorisation. Sorry for the inconvenience.
Thanks so much Ian for your help. Already contacted them. I just hope this goes smooth and fast and I can get the printer finally working soon...
Cheers!!
