    3.0 Heater/Fan configuration
    Firmware installation
    921
    • zemlinundefined
      zemlin
      Have a Rostock delta machine that was running an older 2.x firmware. Upgraded it to 3.0 and now am struggling with the config.g changes. The pin names, sensor names, and new command requirements just aren't clear to me, I'm afraid. Looking at one of my other machines that's already at 3.0, but the machines are different enough I'm not getting there.
      Here are the lines in the original config.g prior to the update.
      M106 P0 H-1 ; Part Cooling Fan
      M106 P1 S0.5 H-1 ; Case fan
      M106 P2 T50 S0.7 H1 ; Heat sink fan
      M307 H0 B0 ; Heated Bed (H2)
      M305 P0 T100000 B4388 R4700 H30 L0 ; Bed thermistor
      M305 P1 T100000 B4388 R4700 H30 L0 ; Hot end Thermistor
      M563 P0 D0 H1 ; Hot end (T0), drive (E0), heater (H1)
      G10 P0 S0 R0 ; Hot end operating and standby temperatures
      and my failed attempt at updated the code for the 3.0 firmware
      M308 S0 P"bed_temp" T100000 B4388 R4700 H30 L0 ; configure sensor 0 for bed heater
      M307 B1 S1.00 ; enable bang-bang mode for heater
      M143 H0 S120 ; set temperature limit for heater 1 to 120c
      The bed doesn't show up in the DWC. Haven't tried the extruder yet.
      Sorry this stuff just doesn't click with me.
      SIamundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • SIamundefined
        SIam @zemlin
        @zemlin It may make more sense if you use the configuration tool to do your basic configuration. If you then have trouble post the entire config.g file. I find it's easier to assist when you post the whole config file instead of some fewer commands.
        The configtool you can find here:
        https://configtool.reprapfirmware.org/Start
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        zemlinundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @zemlin
          @zemlin have you tried running M98 P"config.g" to see if any errors are reported when config.g is run?
          • zemlinundefined
            zemlin @SIam
            @siam When I updated my other machines, the configuration tool had not been updated yet, so didn't know that was in place. Ran through it and got things a lot closer to working. Thank you.
            • zemlinundefined
              zemlin @dc42
              @dc42 I have installed new config files after running the configurator. I'm getting some errors with M98, but I'll see if I can work through those before I come back for more help. Thank you.
                Did you stop at 3.0? You should update to 3.2.2 right away.
                • zemlinundefined
                  zemlin @Phaedrux
                  @phaedrux - was just going to get things working before taking it the rest of the way. Don't plan to stop at 3.0. Thank you.
                    The problem with stopping at 3.0 is that the pin defaults change in the following firmwares. So it's really not a good place to figure the config out.
                    • zemlinundefined
                      zemlin
                      I'm at 3.2.2 and things are in pretty good shape now, but I have one issue I can't figure out.
                      I have the hot-end fan as Fan2 to turn on when the hot end exceeds 40C.
                      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 S1 H1 T40                              ; set fan 2 value. Thermostatic control is turned on
                      I boot up the machine, turn on the heat, and this works fine. There is not a control showing in the DWC dashboard.
                      I'm not exactly sure what triggers the change, but when I went to run a part, the hot-end fan doesn't start up - but in the Dashboard Fan2 appears, and the slider appears to override the thermostatic control and the fan doesn't run.
                      What do I need to change to have it temperature controlled and keep it from appearing on DWC?
                      Complete config.g
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 05 2021 16:33:43 GMT-0400 (Eastern Daylight Time)
                      G90                                            ; send absolute coordinates...
                      M83                                            ; ...but relative extruder moves
                      M550 P"ROSTOCK"                                ; set printer name
                      M665 R144 L291.06 B135 H400                    ; Set delta radius, diagonal rod length, printable radius and homed height
                      M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
                      M552 S1                                        ; enable network
                      M586 P0 S1                                     ; enable HTTP
                      M586 P1 S0                                     ; disable FTP
                      M586 P2 S0                                     ; disable Telnet
                      M569 P0 S0                                     ; physical drive 0 goes forwards
                      M569 P1 S0                                     ; physical drive 1 goes forwards
                      M569 P2 S0                                     ; physical drive 2 goes forwards
                      M569 P3 S0                                     ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                               ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                      M92 X100.00 Y100.00 Z100.00 E91.00             ; set steps per mm
                      M566 X1800.00 Y1800.00 Z1800.00 E900.00        ; set maximum instantaneous speed changes (mm/min)
                      M203 X15000.00 Y15000.00 Z15000.00 E15000.00   ; set maximum speeds (mm/min)
                      M201 X4200.00 Y4200.00 Z4200.00 E5000.00       ; set accelerations (mm/s^2)
                      M906 X1200 Y1200 Z1200 E1200 I30               ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                        ; Set idle timeout
                      M208 Z0 S1                                     ; set minimum Z
                      M574 X2 S1 P"xstop"   ; X min active high endstop switch
                      M574 Y2 S1 P"ystop"   ; Y min active high endstop switch
                      M574 Z2 S1 P"zstop"   ; Z min active high endstop switch
                      ; Z-Probe new code
                      ;M558 P5 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
                      G31 P100 X0 Y0 Z0                    ; Probe trigger and offset values
                      M558 P5 C"^zprobe.in" H5 T6000 I0 A2 S0.05 R0.4 H20 F750
                      M557 R120 S60
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 R4700 H30 ; configure sensor 0 as thermistor on pin bedtemp
                      M307 H0 B0 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4388 R4700 H30 ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S310                                   ; set temperature limit for heater 1 to 310C
                      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                      M563 P0 D0 H1 F0                               ; define tool 0
                      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                      M206 Z01.05
                      M501                                           ; load saved parameters from non-volatile memory
                        Can you show a screen shot of what you're referring to on DWC?
                        • zemlinundefined
                          zemlin @Phaedrux
                          @phaedrux @phaedrux This isn't from the printer in question, but here is where FAN2 will appear. It's not there when the machine first boots up and the fan turns on when the hot end temp exceeds 40C. I haven't done enough to know exactly when FAN2 shows up, but when it does it seems the fan no longer responds to the hot-end temperature.
                            The tool fan slider will control the fan of the currently selected tool.
                            • zemlinundefined
                              zemlin @Phaedrux
                              @phaedrux FAN2 is the issue. That's the fan on the hot end. How do I prevent that from showing up on DWC? It should only be temperature controlled from the extruder heater.
                                Is you DWC also updated to 3.2.2?
                                • DIY-O-Sphereundefined
                                  DIY-O-Sphere
                                  @zemlin said in 3.0 Heater/Fan configuration:
                                  I can only remember darkly, but I think RRF3 once had a problem when the channels are not filled in ascending order.
                                  I would suggest to rename the 2nd fan to F1 and channel to P1
                                  (UTC+1)
                                  Phaedruxundefined zemlinundefined 2 Replies Last reply Reply Quote 0
                                    Phaedrux Moderator @DIY-O-Sphere
                                    @diy-o-sphere said in 3.0 Heater/Fan configuration:
                                    That would make more sense. Fan1 is the recommended port for heatsink fan.
                                    • zemlinundefined
                                      zemlin @Phaedrux
                                      @phaedrux I did not take separate action to update DWC - just dropped the big firmware zip in the system folder. If DWC requires a separate update, I will do that.
                                      • zemlinundefined
                                        zemlin @DIY-O-Sphere
                                        @diy-o-sphere
                                        I did not wire the machine. Will poke my head in the control box to confirm how things are wired and if I might need to switch a couple cables.
                                        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                          DIY-O-Sphere @zemlin
                                          @zemlin
                                          With RRF3, the wiring doesn't need to be changed.
                                          Change the config to
                                          M950 F1 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                          M106 P1 S1 H1 T40 ; set fan 2 value. Thermostatic control is turned on
                                          (UTC+1)
                                            Phaedrux Moderator @zemlin
                                            Normally uploading the full zip should update everything, but if you are using a very old version it might not get picked up I guess.
                                            You can try uploading the DWC zip file by itself and if that doesn't work, use that zip file to replace the contents of the /www folder on the SD card manually.
                                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
