    noob help dule z setup
    779
    • Mobietec
      Mobietec last edited by Mobietec
      hi all in need of a bit of help
      im new to duet and i cant seem to get my head aroud this
      trying to setup dule z axes and then duel z aling my problem is i cant seem to get the jist of the coding to set this up
      im using a trony core xy as a start point this is bening upgraded bit by bit it will have 4 z screws by the time i have finished
      im using duet3 6hc board
      bltouch
      any and all help welcome and thank you in advance Richard
      Mobietec 1 Reply Last reply Reply Quote 0
        Have you seen this?
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        What do you have in your config.g, bed.g, homeall.g files right now?
        What firmware version are you using? Send M115 to check.
        • Mobietec
          Mobietec @Mobietec last edited by
          @mobietec ok here we go with current setup and what i am trying to do
          i have duet 3 main board
          i have bltouch clone for now
          i have an tronxy x5sa chassi
          twin z screws conected sepratley so i can do z aligment
          and 1 extruder
          i wish to run x,y sencerless
          z with bltouch
          size of bed 330x330x400
          bl is conected on io7 as recomeded
          i have heated bed and hot end heat working sort of
          bed heat silcone heat mat by ssr and 24v bed
          i cant configer xy or z propley using standered nema chineas motors for now
          futura upgrades 2 extruders
          3 or 4 lead screws
          • Mobietec
            Mobietec @Phaedrux last edited by Mobietec
            @phaedrux i need to configer basic first i need to get all axies working with bl and sencerless ty
            my gonfig keeps changing at present but this is what i have for now using configerator
            ; bed.g
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 09 2021 20:06:02 GMT+0100 (British Summer Time)
            G29 ; probe the bed and enable compensation
            M550 P"My Printer" ; set printer name
            M669 K1 ; select CoreXY mode
            M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0.1 S1 ; physical drive 0.1 goes forwards
            M569 P0.2 S1 ; physical drive 0.2 goes forwards
            M569 P0.3 S1 ; physical drive 0.3 goes forwards
            M569 P0.4 S1 ; physical drive 0.4 goes forwards
            M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
            M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X330 Y330 Z400 S0 ; set axis maxima
            M574 X1 S3 ; configure sensorless endstop for low end on X
            M574 Y1 S3 ; configure sensorless endstop for low end on Y
            M574 Z2 S2 ; configure Z-probe endstop for high end on Z
            M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
            M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
            G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            M307 H0 R0.612 C635.3 D7.63 S1.00 V24.4 ; disable bang-bang mode for the bed heater and set PWM limit
            M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
            M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
            M307 H1 R3.222 C146.1 D6.93 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit
            M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
            M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
            M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
            M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
            M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
            M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on
            M950 F4 C"out8" Q500 ; create fan 4 on pin out8 and set its frequency
            M106 P4 S1 H1 T45 ; set fan 4 value. Thermostatic control is turned on
            M950 F5 C"out9" Q500 ; create fan 5 on pin out9 and set its frequency
            M106 P5 S1 H1 T45 ; set fan 5 value. Thermostatic control is turned on
            ; homeall.g
            ; called to home all axes
            G91 ; relative positioning
            G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-335 ; home X axis
            G1 H1 Y-335 ; home Y axis
            G1 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y-335 ; then move slowly to Y axis endstop
            G90 ; absolute positioning
            G1 X15 Y15 F6000 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G1 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
            • Mobietec
              M550 P"Raptor CoreXY" ; set printer name
              M569 P0.2 S0 ; physical drive 0.2 goes forwards
              M569 P0.4 S0 ; physical drive 0.4 goes forwards
              M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
              M671 X-20:165 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
              M208 X-5:335 Y0:335 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
              • droftarts
                droftarts administrators @Mobietec last edited by
                @mobietec said in noob help dule z setup:
                I've posted my config.g for TronXY X5A (earlier version of X5SA): https://forum.duet3d.com/topic/23222/setting-up-duet2-wifi-for-tronxy-x5sa/2?_=1621257336334
                It will be largely the same as yours, except I set X0 Y0 at the centre of the bed, and the different names for pins as I'm using Duet 2 WiFi. I use the standard endstops for homing X and Y, and BLTouch on Z. If your microswitch endstops are still fitted, I'd initially use them until you're comfortable changing to sensorless homing. Sensorless homing will be less precise and repeatable than mechanical endstops, as it takes up to 4 full microsteps to register a stall, whereas endstop triggering is checked on each microstep.
                To get your Core XY motors moving correctly, see: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                I'll cover the macros for bed levelling in another post, once you've got the basic movement working.
                If you upgrade the Z, I'd recommend 3-leadscrew rather than 4. See the Jubilee (https://jubilee3d.com/) for an example of a good Z stage. I'd also recommend making any additional extruders independent of the first, either by making it an IDEX, or a toolchanger. Jubilee is a good example of a toolchanger, too.
                Below are notes on your config.g:
                CoreXY mode is set, which is good!
                You have initially set up the printer to have one motor on X, Y and Z, and two E motors. Remove the second E parameter on all of the above. Move the M584 from later on to above this section, replacing the original one.
                Don't put anything that isn't a gcode in the config.g without a ';' comment marker at the beginning.
                Move this up to before the speeds and accelerations.
                These positions for the leadscrews are almost certainly wrong. You need the position of leadscrews relative to the X0 Y0 point. Mine are at X-90, Y165 and X420, Y165 (with X0 Y0 at front left). However, I wouldn't put these in the config.g, as there are two ways of levelling the bed; with the independent leadscrews, and with the manual adjuster screws.
                Wrong format for M208, delete.
                These are fine.
                Don't run before you can walk. Use the microswitch endstops to start off with. See my config.g. Note I have changed the pins on the microswitches the wires are connected to, to the outside two pins, so they are active-high, which is recommended.
                Remove ^ from the pin name. You only need it if you use 'probe.in', which the Duet 3 doesn't have
                Remove this line, not needed for CoreXY. If you initially set up your printer as a delta, make sure you don't have a homedelta.g file in the /sys folder, or that will really mess things up.
                You haven't put in your Z probe offset in X and Y. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                Mesh bed is likely to be bigger than this, as bed is 330x300.
                TronXY use standard 100k Epcos thermistors. Change B parameter to B4092 for better temperature accuracy.
                I'm pretty sure you don't need this many thermostatically controlled fans! Fan 0 should not be thermostatic, anyway, particularly as you have mapped it to Tool 0:
                Please post your M501.
                That should be enough to get on with!
                Mobietec 1 Reply Last reply Reply Quote 2
                • Mobietec
                  Mobietec @droftarts last edited by
                  @droftarts said in noob help dule z setup:
                  B409
                  rather then delete i have put ; i hope this is ok for now just so i can see my changes im about to try this ty
                  • Mobietec
                    ty i have sencerless homing working now on x and y problem with homing z z probe already trigered at start of probing move
                    i have this set op on io7
                    M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                    G31 P500 X-37.20 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                    ; homez.g
                    ; called to home the Z axis
                    G1 X15 Y15 F6000 ; go to first probe point
                    • Mobietec
                      M501
                      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 413C
                      heater works ok thou as you asked for M501
                      • droftarts
                        @mobietec sorry, meant post your sys/config_override.g file, as you have M501 in your config.g. This may be overriding settings in your config.g.
                        Mobietec 1 Reply Last reply Reply Quote 1
                        • Mobietec
                          @droftarts ; config-override.g file generated in response to M500 at 2021-05-17 15:30
                          ; Heater model parameters
                          M307 H0 R0.612 C635.254:635.254 D7.63 S1.00 V24.4 B0
                          M307 H1 R3.237 C65.602:65.602 D6.95 S1.00 V24.3 B0
                          ; Workplace coordinates
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X0.00 Y0.00 Z0.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                          M486 S-1
                          • droftarts
                            droftarts administrators last edited by
                            @mobietec The values in your config_override.g are different from the ones in your config.g. Because you have M501 at the end of config.g, the ones in config_override.g are the ones being used.
                            config.g:
                            config_override.g:
                            However, the ones in config_override.g look more correct to me; they have two values for the C parameter, which means they were done with the new tuning algorithm which adapts for the part cooling fan. The bed tuning looks the same between them, but the hot end differs a little.
                            Either leave it as it is, or comment out M501 in config.g and copy the M307 values from config_override.g to config.g.
                            • droftarts
                              BLTouch troubleshooting: https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
                              Normal operation is:
                              1. When the Duet is first powered up, the BLTouch should perform its self test, which is to light up with red light, and extend and retract pin twice. If this doesn't happen, +5V and GND are not connected correctly.
                              2. Send M280 P0 S10 to extend pin. If this doesn't work, check the wiring to the servo pin. Send M280 P0 S90 to retract the pin.
                              3. The sys/deployprobe.g file and the sys/retractprobe.g file should contain the above two commands, one command in each file. Send M401 to extend the pin. If this doesn't work, check your sys/deployprobe.g file contains M280 P0 S10. Send M402 to retract the probe, and if this doesn't work, check sys/retractprobe.g contains M280 P0 S90.
                              4. With the probe retracted, check in DWC the Z-probe value in the Status panel. It should be 0. If it is 1000, check the probe trigger wire (usually white) is connected to the correct input pin.
                              5. Send M401 to extend the pin. VERY lightly, touch the end. The Z-probe reading should go from 0 to 1000. If it goes from 1000 to 0, you need to invert the probe. If it doesn't change, check the wiring again.
                              6. If doing the above triggers the alarm (flashing red), send M280 P0 S160 to release alarm and retract probe.
                              As you're using a clone BLTouch, and there was another thread recently about clones not working properly (see https://forum.duet3d.com/topic/23218/strange-bltouch-behavior-after-update-to-3-3-0-b3), I expect it could be that the output is inverted, and it reads 1000 when not triggered, and 0 when triggered. If so, invert the probe by changing your M558 line to:
                              M558 P9 C"!io7.in" H5 F120 T6000
                              • Mobietec
                                M280 P0 S160
                                i have just ordered proper bltouch will connect it tommrow and go from their also instaling the end stops if you coudld help in the code for this ill add it in would you like the code i have right now many thanks
                                • droftarts
                                  @mobietec I have mine set like this:
                                  M574 Z0             ; configure Z-probe endstop for low end on Z
                                  I am using the X and Y endstops, BLTouch on Z. The only physical change is that I have wired them using the outer two pins (of three) on each microswitch, for NC (normally closed, or active high) operation, which is more reliable. I think you won't need to change your homing files much, except comment out any lines related to sensorless homing. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                                  If you want to post your current config.g for reference (or maybe after you have made the changed to endstops), please do. It would be good if you could use the 'code' tags around long bits of code, like the endstop code in the black box in this post, to make it easier to read. Click the '</>' icon at the top of the post edit window to insert these tags, and paste the code in between.
                                  • Mobietec
                                    ok for the next bit nd thank you so much for all your help im slowley learning this i think i need to set the off set propley of the bl touch i have gourn back to clone it seems to be working
                                    when i home the z it works so to speek i need to set the bltouch i di put a -37.6 and a 37.6 with no luck the proble is off the bed the nozzle is correct front left ie nearest to you on left
                                    1 i think i need to set home 0 to center trying to look ant fined out how and tryng to do off set
                                    somtimes i think i bit off more that i can chue with duet3 board its very compleacted for me but the end rerult should be good many thakns
                                      The G30 will just start probing at whatever XY position it's currently at, so you'll need to manually position the probe in the homeall.g and homez.g files so that the probe is where you want it to be before the G30.
                                      G1 X150 Y150 F6000
                                      G30
                                      • Mobietec
                                        This post is deleted!
                                        • Mobietec
                                          @phaedrux
                                          @phaedrux my updated config file
                                          i cant get the bltouch to deply now grrr i am trying to look for answers befor i post first i have the bl on io3 now their are two grounds form touch that are wired together sence on io out and triger on ioin
                                          i have checked for contunety lol i cant spell today and i have also tried 3.3 and 5v lines and i have tried diffrent probs still get same
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 19 2021 20:59:11 GMT+0100 (British Summer Time)
                                          M92 X80.00 Y80.00 Z400.00 E440.00:400.00 ; set steps per mm
                                          M566 X900.00 Y900.00 Z60.00 E120.00:60.00
                                          M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 ; set maximum instantaneous speed changes (mm/min)
                                          ;M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                          ;M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                                          M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00 ; set maximum speeds (mm/min)
                                          M208 X-165 Y-165 Z0 S1 ; set axis minima
                                          M208 X165 Y165 Z400 S0 ; set axis maxima
                                          M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
                                          M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
                                          M574 Z2 S2 C"io4.in" ; configure Z-probe endstop for low end on Z
                                          M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
                                          M558 P9 C"io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P500 X-30 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                          M557 X-155:130 Y-155:155 P5 ; define mesh grid
                                          ;M558 A10 S0.003 B0 R0.2 ; BLTouch extra settings from Phaedrux
                                          G31 P500 X-37.6 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                          M307 H1 R3.322 C149.5 D6.72 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit
                                          Phaedrux 2 Replies Last reply Reply Quote 0
                                            Does M401 and M402 work?
                                            Does M280 P0 S10 or M280 P0 S90 work?
                                            What do you have in your deploy and retract macros?
                                            Are those deploy and retract macros located in your /sys/ folder?
                                            • Mobietec
                                              @phaedrux no im trying a clean install see if that helps
                                              • Mobietec
                                                @phaedrux said in noob help dule z setup:
                                                no
                                                no
                                                ; deployprobe.g
                                                ; called to deploy a physical Z probe
                                                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 20:02:55 GMT+0100 (British Summer Time)
                                                M280 P0 S10 ; deploy BLTouch
                                                ; retractprobe.g
                                                ; called to retract a physical Z probe
                                                M280 P0 S90 ; retract BLTouch
                                                yes
                                                  99.9% of the time it's wiring.
                                                  • Mobietec
                                                    @phaedrux i fully understand that i have checked and rechecked im using duet 3
                                                    bl conected to io3
                                                    5volt to 5volt in bl
                                                    io out to sig
                                                    both grounds from bl to gnd
                                                    and out(z) to io3 in
                                                    rom socket to bl no broken conections and correct readings ie cable conected ok
                                                    hope this helps
                                                      Phaedrux Moderator @Mobietec last edited by
                                                      bl conected to io3
                                                      io out to sig
                                                      Are you using io3 or io4?
