    Heater fault occurs frequently
    • kvlunagariyaundefined
      kvlunagariya
      Hello, I am using J type thermocouple sensor for the heater but heater is going in fault mode frequently. when i move sensor wire little bit i comes back to normal condition.
      Please suggest any solution for this problem
      jens55undefined engikeneerundefined droftartsundefined 3 Replies Last reply Reply Quote 0
      • jens55undefined
        jens55 @kvlunagariya
        @kvlunagariya , replace sensor .... ?
        • engikeneerundefined
          engikeneer @kvlunagariya
          @kvlunagariya or replace the wiring, if moving it around makes it work/not work
          i3 clone with a bunch of mods
            droftarts administrators @kvlunagariya
            @kvlunagariya Sounds like a wiring issue, or the thermocouple wires are shorting out or damaged. See our thermocouple wiring advice here: https://duet3d.dozuki.com/Wiki/Connecting_thermocouples#Section_Troubleshooting
