    HangMower for alpine meadows?
    Using Duet Controllers
    856
    • o_lampeundefined
      o_lampe
      Hi gents,
      just want to pass another crazy idea I got when watching Swizz people mowing a meadow with a scythe.
      There are many steep hills in the Alps, where machines can't mow.
      Would it be possible to construct a hangmower to mow these uneven and steep meadows?
        Kind of like those vertical chain CNC routers that hang on a wall?
          dc42 administrators @o_lampe
          @o_lampe said in HangMower for alpine meadows?:
          I guess so, but you would need a very tall tower or tree at each corner of the meadow.
          • o_lampeundefined
            o_lampe @dc42
            we had a different thing in mind, when we talked about hangprinter.
            I thought of a vertical surface where the effector (mower) is guided by two ropes building a triangle (from gravity) as I've seen on huge 2D wall plotters/painters.
            In this special case the wall wouldn't be vertical, but a steep hill...
              @o_lampe I see what you mean, it's essentially a 2D version of Hangprinter. I think you would still need to pass each rope through a pulley on a short tower or some other type of support at the top of the slope, to keep the ropes clear of the ground so that it doesn't snag on uneven ground. I guess the mower could be of the hover type, and the ropes could be cables that also supply power to it.
              Alternatively, use goats.
              CNCModellerundefined fmaundefined 2 Replies Last reply Reply Quote 3
              • CNCModellerundefined
                CNCModeller @dc42
                @dc42 does RRF support the Maslow CNC router style kinematics? It's essentially what's been discussed here.
                Been thinking about DIY building one of these for quite a while. Future larger workshop means it's a practical proposal.
                https://youtu.be/y60q6U7NjTQ
                Polar Duet3 Mini + 1HCL
                https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                Wanhao D4S: Duet2
                https://forum.duet3d.com/post/296755
                K40 Laser, Duet2
                https://forum.duet3d.com/post/312082
                Wanhao D5S
                https://www.youtube.com/CNCModellerUK
                  dc42 administrators @CNCModeller
                  @cncmodeller said in HangMower for alpine meadows?:
                  No, but I don't think it would be hard to add. https://github.com/Duet3D/RepRapFirmware/wiki/Adding-New-Kinematics
                  CNCModellerundefined 1 Reply Last reply Reply Quote 0
                    CNCModeller @dc42
                    @dc42 Thanks for the direction... I'll pick it up once I've moved workshop, I've always fancied looking into custom kinematics and my gut says this is an easy place to begin.
                    πŸ™‚
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
                    • fmaundefined
                      fma @dc42
                      @dc42 said in HangMower for alpine meadows?:
                      Are they Duet3-compatible? πŸ˜‰
                      FrΓ©dΓ©ric
                      o_lampeundefined 1 Reply Last reply Reply Quote 1
                      • o_lampeundefined
                        o_lampe @fma
                        @fma said in HangMower for alpine meadows?:
                        Well, they sort of work like an pellet extruder πŸ˜‰
                        But seriously, these people have to mow the meadows to feed their cows in winter.
                          So you need a mower that collects the grass too. I guess you could have a grass hopper on top of the hang mower, and periodically haul it to the top or drop it to the bottom to empty it.
                          I wonder if it would be possible to have two hang mowers using a single pair of motors, one mower for each half of the meadow, so that they balance each other and thus take less energy to move up and down the meadow.
                          • o_lampeundefined
                            o_lampe @dc42
                            thanks for taking a deeper look into the subject. AFAIK, they let the grass dry and collect it a few days later.
                            I'm not sure if using another mower as counterweight would work, since (in my imagination) the whole line-stretching principle is based on gravity? But it would be a great idea, if not too expensive?
                            I'd like to setup a test rig, but I'm not sure if 'hangprinter kinematic' will work out as it's 2D only?
                              @o_lampe you would need to write a new kinematics class, however it would be quite a simple one.
                              • o_lampeundefined
                                o_lampe @dc42
                                It's the compiling, I'm afraid off and I never had to figure out inverse kinematics before. There also needs to be a correction for the changing spool diameter. (rope winding up in layers)
