Duet2 or Duet3 for new Jubilee build
@dougal1957, thanks .... that pretty much only leaves the 6HC board as a viable contender.
@jens55 said in Duet2 or Duet3 for new Jubilee build:
not really as you could use a 3hc as a slave to a duet3mini but you don't have to run the XY motors flat out if you don't want to but I wouldn't go below 1.6A
@dougal1957, grrrr, just as I made the decision ..... this is hard
I knew the question would come up.
This is something that has been on my mind for a long time.
I want to park my tools in the front, but here they are in the way for maintenance work. So I was thinking about moving a tool platform in Z.
But this should only happen when needed, not for a tool change.
For example, at the end of a print to get more space to reach in.
I already have a concept and first CAD drafts for this. -
@diy-o-sphere ah ok makes some sense i guess but that could be done with low current motors I guess you would have to ensure that they always come bake to the normal position quite accurately tho.
