    Solved Home offset in RRF?
    • Impalanator
      Impalanator last edited by
      I have a 6HC and I'm almost done configuring this custom printer. I have a 330x330mm build plate and the print head is not center on the bed when I go to X=115 Y=115. I have a lot of experience with Marlin and I would adjust the HOME OFFSET to fix this issue (M206). I can't find a similar command in RRF. The closest thing I found was a tool offset but I don't believe that is going to achieve what I'm after. Can someone point me in the right direction with this one?
      Here is my config.g file
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri May 07 2021 11:46:55 GMT-0500 (Central Daylight Time)
      M550 P"Duet 3"                                     ; set printer name
      M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
      M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
      M569 P0.4 S0                                       ; physical drive 0.4 goes backwards
      M569 P0.5 S1                                       ; physical drive 0.5 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3 E0.4:0.5                   ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1                         ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E420.00:420.00         ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00         ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00    ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00         ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M208 X330 Y330 Z400 S0                             ; set axis maxima
      M574 X1 S1 P"!io0.in"                              ; configure active-high endstop for low end on X via pin !io0.in
      M574 Y1 S1 P"!io1.in"                              ; configure active-high endstop for low end on Y via pin !io1.in
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F120 T6000                   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X21.73 Y30.22 Z2.5                        ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4116.93    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M307 H0 R0.126 C377.1 D2.42 S1.00 V23.9		       ; pid tuning settings
      M308 S1 P"temp1" Y"thermistor" T100000 B3950       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 R2.275 C212.6 D10.63 S1.00 V23.9
      M950 F0 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      G10 P0 X0 Y80 Z0                                    ; set tool 0 axis offsets
      M563 P1 D1 F0                                      ; define tool 1
      G10 P1 X0 Y80 Z0                                    ; set tool 1 axis offsets
      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      Thanks much
      o_lampe droftarts 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @Impalanator last edited by
        @impalanator said in Home offset in RRF?:
        115 is not half of 330 🙂
        So the printhead won't be at the center....
        Impalanator 1 Reply Last reply Reply Quote 0
        • droftarts
          droftarts administrators @Impalanator last edited by
          @impalanator see https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
          • Impalanator
            Impalanator @o_lampe last edited by
            @o_lampe Thanks, that was a typo, but the question still remains, how do you change the home offset to compensate for the print head being offset?
            • Impalanator
              Impalanator @droftarts last edited by
              @droftarts Thanks, this is exactly what I was looking for.
