Software package 3.3-rc2 released
We're happy to announce the second release candidate of the upcoming stable version 3.3. The most important changes were fixes for SBC users involving macro calls and upgrades from the stable branch (i.e. not from a previous 3.3-beta). We hope there won't be any further problems holding up the next stable release.
Please see the following links for complete changelogs and/or upgrade notes:
- For RRF: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-33rc2
- For DSF: https://github.com/Duet3D/DuetSoftwareFramework/blob/v3.3-dev/WHATS_NEW.md#version-33-rc2
- For DWC: https://github.com/Duet3D/DuetWebControl/blob/v3.3-dev/WHATS_NEW.md#version-33-rc2
Users in standalone mode can obtain the latest DWC and RRF packages from here. Other users in SBC mode should upgrade via the unstable package feed via
apt update
/apt upgrade
.If you do have any more issues with this version, please create a new topic with
[3.3-rc2]
in the title in the Beta Firmware category after having checked there isn't already an identical report. -
Just a reminder that software bundle 3.3RC2 is available, including fixes for issues seen in earlier 3.3beta and RC releases, along with a new feature that allows tools to be pre-heated without having to select them using T commands.
I'll list confirmed bugs in 3.3RC2 here, for the benefit of anyone considering upgrading. Starting with this one, which is also present in earlier 3.3 betas and RC1:
- [Duet 2 WiFi and Duet 3 Mini WiFi] When using M589 to set up the Duet to provide its own access point, the C (channel number) parameter cannot be used. There are 3.3RC2+1 binaries that fix this at https://www.dropbox.com/sh/zbqzr0g7h4x0jqt/AADYby53148rqmRx9UdCPrBxa?dl=0.
We have finally reached a point where we can begin testing 3.3. No issues so far, but I did want to go ahead and say M17 is working great!
Firmware 3.3RC2 appears to be working well and we hope to release 3.3 stable next week. So you have only a few days left to report issues in firmware 3.3RC2 that were not present in the last stable release (3.2.2).
@dc42 one small issue
Limit accelerometer SPI frequencies to 500000 to 10000000 (500kHz to 10MHz)
I think you mean from 500000 to 1000000015.5.2021, 15:31:08 M955 P0 C"spi.cs3+spi.cs4" S4800 Q10000000 R12 I20 Error: M955: parameter 'Q' too high
@dc42 said in Software package 3.3-rc2 released:
Hiya - I've updated to RRF 3.3RC2 and having trouble turning the router spindle on/off. I've amended the following in my config.g file.
M453 ; Set to CNC mode M950 R0 C"e1heat+e0heat" L0:24000 Q300 ; Select Spindle On/Off,RPM & Direction M563 P1 S"Spindle" R0 ; Define Tool
If I try to turn the spindle on with RPM speed of 5000, using an M3 S5000 I get this error:
Warning: M3: No spindle selected via P and no active tool with spindle
If I send M3 S5000 P1 I get the following error:
Error: M3: internal error at file../src/GCodes/GCodeBuffer/StringParser.cpp(1362)
Is that something to address?
May 16 10:49:24 Cube DuetControlServer[197]: [warn] IPC#16: Client with outdated protocol version connected (got 7, want 11)
@siam said in Software package 3.3-rc2 released:
You are right, the code doesn't allow Q10000000 but does allow Q9999999. I will fix this in 3.3 stable.
@martinnyhc said in Software package 3.3-rc2 released:
We need to update the Go and Python client APIs that can be used on the Pi. Are you using one of those?
@dc42 Yes, the Python API.
@educatingsavvas said in Software package 3.3-rc2 released:
I confirm this is a bug. Please try the new binary at https://www.dropbox.com/sh/zbqzr0g7h4x0jqt/AADYby53148rqmRx9UdCPrBxa?dl=0 and let us know whether it behaves as you expect.
EDIT: I have just updated those binaries to fix M4 as well.
That seems to work now - although I'm not aware of any CNC platforms using g-code in that way. Normally the tool is specified with T followed by the number in the software's tool database. I am planning to have three tools on my CNC machine - one router spindle, a diode laser and a tangential knife. Are there any particular advantages for the change?
I noticed a strange behavior after I updated from 3.2.2 to 3.3RC2.
I have a filament presence switch that I use for triggering filament load macro.
After I updated to 3.3RC2 it seems to be a lot of false triggers.
Powering up printed, it does nothing for about 3 minutes and suddenly starts triggering and display messages:
Error: Attempting to extrude with no tool selected.I do not need to start print or do anything. Just power on printer and wait.
Duet3 standalone setup.
My config files:
trigger3.g
config.g
fs_enable.g
fs_disable.g
fs_config.g -
We need to report a significant issue in 3.3-rc2 when using a 6HC with attached SBC.
When canceling a print, "stop.g" is called, not "cancel.g" like in previous versions of the firmware. This was validated by putting M291 P"Stop" at the top of stop.g and M291 P"Cancel" at the top of cancel.g.
@boa said in Software package 3.3-rc2 released:
My config files:
trigger3.g
config.g
fs_enable.g
fs_disable.g
fs_config.gI doubt that this has anything to do with firmware changes. I think your filament out switch is getting triggered, or picking up interference, or has a bad connection. You enable it in config.g but your trigger3.g file doesn't check whether there is a current tool, or that a file is being printed and has not been paused.
@oozebot said in Software package 3.3-rc2 released:
Thanks, I've asked @chrishamm to take a look.
@dc42 I would think that is the case if such behavior was also on 3.2.2, but with 3.2.2 it works just fine without false triggers.
Have you tried switching between 3.2.2 and 3.3RC2 more than once? It wouldn't be the first time that the first appearance of a problem caused by a bad connection happened to coincide with a firmware update.
@dc42 Yes. Reverting to 3.2.2 fixes that strange behavior. I tried 3 times. I did not try intermediate versions to identify which one introduces that.
Edit: This behavior is in 3.3beta1
Thanks for your report, I've got a fix ready for this.
@boa I am trying to reproduce your issue. So far the trigger hasn't gone off; but I have nothing connected to IO8_IN. What type of filament switch is it? Is is closed when filament is present, and open when it is not; or the other way round? Do you have filament in in when this issue occurs?
For those testing with 3.3RC3 the latest firmware binaries are at https://www.dropbox.com/sh/duc057ejldxhl48/AADiuF-oiz9EmkFX6HCeodxTa?dl=0. The change list since the 3.3RC2 release is https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-33-post-rc2.
My test system has been sitting for almost 9 hours, and still no false triggers.
@dc42 will these soon be pushed to the apt repos?
