    External drives
    • RASA
      RASA last edited by
      Hi
      How do I connect external stepper drives to the duet 3 6HC ? I don't see any jumper pins on the board. How many external drives can I connect directly to the board ?
      The add on boards seem to have a lower step frequency.
      Is there a dedicated pin to invoke a homing routine on an external drive ? and another for the reply ?
      Thanks
      Harald
        I think you'd be wanting to use this: https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD
        RASA 1 Reply Last reply Reply Quote 0
        • RASA
          RASA @Phaedrux last edited by
          @phaedrux
          Hi, thanks for the quick reply !
          No, rather not. On boards with jumpered drives I took out the drives and connected the external drives there. On some other boards with soldered drives there are jumpers, where you can get the signals. In the schematics of the duet 3 I only found test points for these signals.
          Dougal1957 MaxGyver 2 Replies Last reply Reply Quote 0
          • Dougal1957
            Dougal1957 @RASA last edited by
            @rasa would https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD be what you need?
            • MaxGyver
              MaxGyver @RASA last edited by
              @rasa
              AFAIK there are no pinouts for stepper signals on the duet3 6HC. The most elegant solution is indeed what @Phaedrux and @Dougal1957 have suggested. The Duet 3 Expansion 1XD board provides all the pins you need for connecting external stepper drives and has extra fuses for safety.
              -Max
