    Hang printer - Print stops with mesh leveling
    Using Duet Controllers
    7.6k
      Phaedrux Moderator @Shinomori
      @shinomori said in Hang printer - Print stops with mesh leveling:
      M558 P0 H5 F120 T6000
      In case you're still at the printer to test.. Would you be able to try increasing the dive height? M558 H5 to H15? I just noticed that your M208 Z minima is -5mm which is the same as your dive height.
      Shinomoriundefined 1 Reply Last reply Reply Quote 0
      • Shinomoriundefined
        Shinomori @Phaedrux
        @phaedrux
        We'll probably be over later this week to work on it some more. I'll try setting the dive height larger than the z minima. And the other way around. It is interesting that probing one point manually currently works. Used to establish Z0 to before trying to create a mesh level. It only fails when trying to do the mesh. So it seems there is something odd there. It still does load the old mesh file from the last time I ran it before doing all the updates.
          Can you post the heightmap.csv file from the previously saved G29 run?
            Shinomori @Phaedrux
            @phaedrux
            Ok I tried:
            M558 P0 H15 F120 T6000
            M208 Z-5 S1
            and:
            M208 Z-15 S1
            In both cases:
            I ran G28 X0 Y0 Z0 E0 U0 then G30. The manual probing screen came up but the print head didn't move after setting height it moved up the dive height in M558. The running G29 this came up:
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=0.0, Y=200.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=-200.0, Y=200.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=-200.0, Y=0.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=0.0, Y=0.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=200.0, Y=0.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=200.0, Y=-200.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=0.0, Y=-200.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM Warning: Skipping grid point X=-200.0, Y=-200.0 because Z probe cannot reach it
            7/12/2021, 12:44:49 PM G29
            Error: Too few points probed
            Here is the config:
            G91 ; send relative coordinates...
            M550 P"duet3" ; set printer name
            M569 P0.0 S0 ; physical drive 0.0 goes forwards
            M569 P0.1 S1 ; physical drive 0.1 goes forwards
            M569 P0.2 S0 ; physical drive 0.2 goes forwards
            M569 P0.3 S1 ; physical drive 0.3 goes forwards
            M569 P0.4 S0 ; physical drive 0.4 goes forwards
            M584 X0.0 Y0.1 Z0.2 E0.3 U0.4 ; set drive mapping
            M669 K6 A0.0:-2265.0:0.0 B1725.0:1100.0:0.0 C-1740.0:1120.0:0.0 D0.0:0.0:2666.0 P1500.0
            M350 X16 Y16 Z16 E16 U16 I1 ; configure microstepping with interpolation
            M92 X92.90 Y92.90 Z92.90 E396.00 U93.00 ; set steps per mm
            M566 X900.00 Y900.00 Z900.00 E120.00 U900.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z6000.00 E1200.00 U6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z500.00 E250.00 U500.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E800 U1000 I60 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 Z-15 S1 ; set axis minima
            M208 Z1500 S0 ; set axis maxima
            ; WARNING: No endstops configured
            M558 P0 H5 F120 T6000; disable Z probe but set dive height, probe speed and travel speed
            G31 P500 X0 Y0 Z0
            M557 R400 S200
            ;M557 X-100:100 Y-100:100 S100 ; define mesh grid
            M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
            M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
            M143 H0 S270 ; set temperature limit for heater 0 to 270C
            M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M140 H-1
            M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
            M106 P0 S0 H0 ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
            M106 P1 S0 H0 ; set fan 1 value. Thermostatic control is turned off
            M563 P0 S"Extruder" D0.3 H0 F0 ; define tool 0
            M564 S0 H0 ;allow move without homing
            T0 ; select first tool
            Shinomoriundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              Shinomori @Shinomori
              @shinomori
              Here is the height map from the old config.
              heightmap.csv
                M208 Z-5 S1
                This would be preferable.
                So when G30 is sent with M558 P0 set, there should be a prompt pop up to allow you to jog the Z axis up and down. Did that happen? Are you saying the movement buttons did not respond?
                  Shinomori @Phaedrux
                  @phaedrux
                  When sending the G30 command the the print head doesn't move and the ui for moving the axis comes up. The buttons work to move the print head. I use those buttons to set the height and hit ok. Then the head moves up to the dive height.
                  When sending G29 there is no motion only errors.
                  When it was working it would move to the location for each probe at z=H parameter in M558.
                  I wonder if the lack of motion at the start of G30 is an indication of what is causing the G29 to fail?
                    That's exactly how M558 P0 and manual probing works. You have to manually move the nozzle to touch the bed. So G30 sounds like it's working.
                    Once you've done that G30 and set the Z0 position are you able to jog the print head around manually?
                    With M558 P0 set, using G29 should indeed prompt you to jog down at each point.
                    And just to confirm, that's with this set?
                    M208 Z-5 S1
                      Shinomori @Phaedrux
                      @phaedrux
                      It moves around fine after g30. I can move it in a very large space and when I send it back to home it is right to the correct spot.
                      The behavior was the same with:
                      M208 Z-5 S1
                      and:
                      M208 Z-15 S1
                      Tried both.
                        Ok, so G30 is working, but G29 still complains that it can't reach all the points.
                        At this point we don't know if it's a problem with the hang printer kinematic, the SBC DSF implementation, or a firmware problem, or some combination.
                        Far as I know, you're the first one trying this.
                        Things to test to narrow it down would be to try testing in standalone mode without the Pi as we discussed before. Though this would require running an ethernet cable up to the Duet.
                          Shinomori @Phaedrux
                          @phaedrux Was in the area and stopped by real quick. Tried running a G90 or G91 right after establishing the home. Tried this with dive bigger than minima and smaller and with the Z minima set to 0. All cases the G30 worked but the G29 still did not.
                          Next step is to connect direct to duet with cable.
                          The dive is currently set slightly larger than the Z minima. Here is the current config.
                          M208 Z-5 S1 ; set axis minima
                          M558 P0 H6 F120 T6000; disable Z probe but set dive height, probe speed and travel speed
                          G31 P500 X0 Y0 Z0
                          M557 R400 S200
                          M140 H-1
                          Shinomoriundefined 1 Reply Last reply Reply Quote 1
                            @shinomori
                            Ok connected direct to duet. Pi is unplugged from it.
                            Connected to it.
                            Used G1 S2 commands to tighten individual axis to get to home location.
                            Sent
                            G92 X0 Y0 Z0 E0
                            G90
                            G30
                            Manual probe worked.
                            Moved head back to 0,0,0 with ui buttons.
                            Sent G29
                            This error:
                            g29
                            M98 P"config.g"
                            HTTP is enabled on port 80
                            FTP is disabled
                            TELNET is disabled
                            M115
                            FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2021-06-15 21:45:56
                            Config.g:
                            M550 P"Hangprinter" ; set printer name
                            M552 P192.168.2.1 S1 ; enable network and acquire dynamic address via DHCP
                            M553 P255.255.255.0
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            G31 P500 X0 Y0 Z0
                            M557 R400 S200
                            M140 H-1
                              Can you try with a different M557 command?
                              Try M557 R200 S50
                                Shinomori @Phaedrux
                                @phaedrux
                                That one still says it can't reach the points with same procedure as before. Just many more points.
                                g29
                                Warning: Skipping grid point X=-100.0, Y=-150.0 because Z probe cannot reach it
                                and so on.
                                  Thanks for testing. At this point we will have to wait for DC42 to return from vacation to be able to investigate further.
                                    Shinomori @Phaedrux
                                    @phaedrux Thanks for feedback. Sorry for being a pain with this. I've run into the limit of my knowledge.
                                    Interesting test Tobben suggested on discord. I set the home position around z150 and sent a g1 z-100 command in absolute mode. It allowed it. The lines didn't maintain tension which is not too surprising asking for something so far out of norm. But there was no error. Hopefully that helps with diagnosis.
                                      Mine too.
                                      Does anyone else on the discord server have a hand printer on Duet 3 running 3.3 that can confirm whether G29 works for them or not?
                                      Shinomoriundefined 2 Replies Last reply Reply Quote 0
                                        Shinomori @Phaedrux
                                        @phaedrux I copied the basic delta config for motors and set home and tried G29 and it worked unless the M557 was too big then it threw the same errors. Converted back to HP config. Tried G1 movement commands in absolute mode well past the M557 limits and it was allowed and the printer moved to those locations. The G29 still threw errors for all points.
                                          Shinomori @Phaedrux
                                          @phaedrux I haven't seen another duet3 HP other than the V4 Tobben is working on but I asked to see if someone responds. Looking forward to what DC42 thinks. Hopefully the book above gives the clues needed. hehe Thanks for your help.
                                            dc42 administrators @Shinomori
                                            @shinomori I've looked at the code and the limits that apply are those set by M208. So make sure that your limits are sufficient, for example M208 X-300:300 Y-300:300.
                                            I also notice that in your config.g file you do not hide the U axis. This may be because you need to move U (aka D in Hangprinter terminology) manually sometimes. However, it means that RRF will check that D is within limits too. So I suggest you hide the U axis using M584 P3 when you don't need to move it manually, in particular when running G29.
