    Firmware from 2.02 to 2.05.1
    Firmware installation
    758
    • FlyingScotundefined
      FlyingScot
      My printer has been working perfectly for years untiI I upgraded to 2.05.1 to use a laser filament sensor.
      Since the upgrade the printer is stuttering around radius moves.
      Has anyone else had this kind of problem? I did copy the sd card before upgrading can I revert back to old firmware?
      Arthur
      FlyingScotundefined 1 Reply Last reply Reply Quote 1
        FlyingScot @FlyingScot
        @flyingscot
        I have gone back to firmware v2.01 and the printer is working perfectly again so it is either the firmware upgrade that is causing the stuttering radial moves or the addition of the laser filament sensor.
        Has anyone any idea what may be causing this?
        Art
          Would help to see the config.g and the results of M122 after it had stuttered.
            FlyingScot
            @phaedrux The problem seems to be between v2.01 and v2.02.
            2.01 perfect as it was before but with v2.02 x and y motors are stuttering on radial moves.
            Both with the same config file.
            I have also removed the filament sensor so it is not that
            Art
            droftartsundefined 1 Reply Last reply Reply Quote 1
              droftarts administrators @FlyingScot
              @flyingscot big list of changes between those two. https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-1.x-&-2.x#version-202-duet-2-series-and-123-duet-06085
              As I’m lacking the powers of omniscience and omnipresence, if you’d like help resolving this, please give more info like @Phaedrux asked for.
              FlyingScotundefined 1 Reply Last reply Reply Quote 0
                FlyingScot @droftarts
                @droftarts
                Hi Ian
                I did notice that in the change logs.
                I also tried to include the results of m122 but they were flagged as spam. how do you upload them?
                Art
                  @flyingscot I’ve given you some upvotes, you should be able to post them now.
                    @droftarts
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
                    Board ID: 08DGM-917NK-F23T0-6JTF0-3SJ6J-TY84G
                    Used output buffers: 3 of 20 (15 max)
                    Static ram: 28476
                    Dynamic ram: 96284 of which 16 recycled
                    Exception stack ram used: 508
                    Never used ram: 5788
                    Tasks: NETWORK(ready,464) HEAT(blocked,1248) MAIN(running,3132)
                    Owned mutexes:
                    Last reset 00:21:16 ago, cause: software
                    Last software reset at 2021-05-14 23:23, reason: User, spinning module GCodes, available RAM 11488 bytes (slot 2)
                    Error status: 16
                    Free file entries: 9
                    SD card longest block write time: 360.5ms, max retries 0
                    MCU temperature: min 31.3, current 31.9, max 32.4
                    Supply voltage: min 11.8, current 11.9, max 12.2, under voltage events: 0, over voltage events: 0
                    Driver 0: standstill, SG min/max 0/307
                    Driver 1: standstill, SG min/max 0/225
                    Driver 2: standstill, SG min/max 0/0
                    Driver 3: standstill, SG min/max 0/259
                    Driver 4: standstill, SG min/max 0/0
                    Date/time: 2021-05-15 00:27:32
                    Slowest loop: 78.47ms; fastest: 0.08ms
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 150, MaxWait: 2ms, Underruns: 0, 0
                    Scheduled moves: 1557, completed moves: 1558
                    Bed compensation in use: none
                    Bed probe heights: 0.355 -0.692 0.000 0.000 0.000
                    Heater 0 is on, I-accum = 0.2
                    Heater 1 is on, I-accum = 0.8
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 362.38ms; fastest: 0.08ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is running
                      Failed messages: pending 0, notready 0, noresp 1
                      WiFi firmware version 1.22
                      WiFi MAC address bc:dd:c2:89:a1:95
                      WiFi Vcc 3.42, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 28600
                      WiFi IP address 192.168.1.100
                      WiFi signal strength -38dBm, reconnections 0, sleep mode modem
                      === Expansion ===
                    This is the one that stutters and slows during radial moves both x and y motors.
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
                    Used output buffers: 3 of 20 (13 max)
                    Static ram: 25524
                    Dynamic ram: 98596 of which 12 recycled
                    Exception stack ram used: 416
                    Never used ram: 6524
                    Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,1692) IDLE(ready,200)
                    Owned mutexes:
                    Last reset 00:07:15 ago, cause: software
                    Error status: 16
                    Free file entries: 10
                    SD card longest block write time: 355.0ms, max retries 0
                    MCU temperature: min 29.9, current 30.8, max 31.2
                    Supply voltage: min 11.8, current 12.0, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: standstill, SG min/max 0/299
                    Driver 1: standstill, SG min/max 0/219
                    Driver 2: standstill, SG min/max 0/31
                    Driver 3: standstill, SG min/max 0/244
                    Driver 4: standstill, SG min/max 0/45
                    Date/time: 2021-05-14 23:59:23
                    Cache data hit count 1572954085
                    Slowest loop: 199.40ms; fastest: 0.07ms
                    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 150, MaxWait: 83163ms, Underruns: 0, 0
                    Scheduled moves: 0, completed moves: 0
                    Bed probe heights: 0.100 -0.095 0.000 0.000 0.000
                    Heater 1 is on, I-accum = 0.5
                    Segments left: 0
                    === Network ===
                    Slowest loop: 355.16ms; fastest: 0.00ms
                    • WiFi -
                      WiFi flash size 4194304, free heap 29000
                      WiFi signal strength -39dBm, reconnections 0, sleep mode modem
                      @flyingscot
                      Config
                      M111 S0 ; Debugging off
                      G21 ; Work in millimetres
                      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                      M564 H0 ; Limit axis
                      :M572 D0 S0.22 ; Set extruder pressure advance.
                      M667 S1 ; Select CoreXY mode
                      M550 P"dBOT" ; Set machine name
                      M552 S1 ; Enable network
                      M587 S"BT-2TA8SR" P"9T9eXAftdqtvfJ" ; Configure access point. You can delete this line once connected
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M584 X0 Y1 Z2:4 E3 ; 2 Z motors connected to driver outputs 2 & 4
                      M671 X-80:480 Y200:200 S10 ; Z lead screws are at (-80,200) (480,200)
                      M579 X1.0015 Y1.003
                      M569 P3 S1 ; Drive 3 goes backwards
                      M569 P4 S0 ; Drive 4 goes backwards
                      M350 X128 Y128 Z128 E16 ; Configure microstepping without interpolation
                      M92 X800 Y800 Z3200 E408 ; Set steps per mm
                      M566 X600 Y600 Z120 E2000 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X9000 Y9000 Z600 E6000 ; Set maximum speeds (mm/min)
                      M201 X600 Y600 Z300 E5000 ; Set accelerations (mm/s^2)
                      M205 X15 : set x and y jerk
                      M906 X1000 Y1000 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X380 Y380 Z400 S0 ; Set axis maxima
                      M574 X1 Y2 S0 ; Set active low endstops
                      M558 P8 I1 X0 Y0 Z1 F200 T1000 ; Set Z probe type to unmodulated and the dive height + speeds
                      G31 P1000 X-50 Y5 Z0.612 ; Set Z probe trigger value, offset and trigger height
                      M557 X20:380 Y40:380 S75 ; Define mesh grid
                      :M591 D0 P5 C4 S0
                      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                      M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                      M143 H1 S285 ; Set temperature limit for heater 1 to 280C
                      M307 H1 A318.9 C165.3 D2.7 B0
                      M307 H0 A312.4 C710.8 D0.8 B0
                      M106 P0 S255 ; Set fan 0 tool fan half speed
                      M106 P1 S1 I0 F500 T45 H1 ; Set fan 1 tool1 heatsink fan on at 45 degrees
                      M106 P2 S0 ; Set fan 2 is turned off
                      M501
                      M563 P0 D0 H1 F0 ; Define tool 0
                      T0
                        Phaedrux Moderator @FlyingScot
                        @flyingscot said in Firmware from 2.02 to 2.05.1:
                        Try again, but switch to x16 microsteps with interpolation enabled I1. Adjust the steps per mm accordingly.
                        The difference may be that it's using quad stepping in older firmware but not in the newer firmware.
                          FlyingScot @Phaedrux
                          @phaedrux Morning
                          Unfortunately it is still the same.
                          its strange printing a circle anticlockwise the speed is not constant it slows down between 2 o'clock and 10 o'clock and again between 8 o'clock and 4 o'clock,
                          Back to 2.01 and its fine.
                          Printer is a core x,y
                          Change to config was:
                          M350 X16 Y16 Z16 E16 I1 ; Configure microstepping
                          M92 X100 Y100 Z400 E408 ; Set steps per mm
                          Art
                            dc42 administrators @FlyingScot
                            Is the circle commanded using G2/G3 or using a sequence of G1 moves?
                            The usual cause of slowing down on curves is jerk set too low in M566.
                              FlyingScot @dc42
                              @dc42 I will look into not sure where to look. The test file is a cylinder drawn in solidworks saved as an stl and sliced with cura. it prints well with V2.01 but not in V2.02.
                              M566 in config is: M566 X600 Y600 Z120 E2000
                              Art
                                @flyingscot, check that the GCode file does not contain any M205 commands, because they would change the jerk limit. I don't remember which RRF version was the first to support M205.
                                  FlyingScot @dc42
                                  @dc42 The circle is generated by G1 moves and there is no M205 in the GCode.
                                  Art
                                    @flyingscot Its now running well on v2.05. It must have been the microstepping with interpolation that fixed it.
                                    I did go back to 2.02 and the problem returned. Back to 2.05 and all is well.
                                    Thanks for your help
                                    Art
                                      Glad it's working well now. I suspect that if you'd run with the higher stepping on 2.05 and done a M122 it would have shown some hiccups.
