    Help to config Servo MG995 for Duet3 6HC
    Third-party add-ons
    565
    • sntundefined
      snt
      Hello folks,
      I have a problem with a servo M995. I just can't get it to work. I've already searched the forum for the problem:
      Wiki Using servos and controlling unused IO pins
      -> duet-2-on-rrf3-servos-not-working
      -> servos-not-working-correctly
      ->help-configuring-rc-servo-for-spindle
      Unfortunately I didn't get any further.
      I have the firmware version: 3.2.2, electronics: Duet 3 MB6HC 1.0 + raspberry pi 3, firmware_date: 2021-02-11 and the Duet Control Server v3.2.2
      Here is my M112
      M122: === Diagnostics ===
      RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: XXXXX-956L2-G43S4-6J9D4-3SJ6S-TA66H
      Used output buffers: 1 of 40 (10 max)
      Static ram: 149788
      Dynamic ram: 62876 of which 24 recycled
      Never used RAM 146144, free system stack 180 words
      Tasks: Linux(ready,85) HEAT(blocked,281) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1165) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 00:02:06 ago, cause: power up
      Last software reset at 2021-05-16 15:41, reason: User, none spinning, available RAM 146144, slot 1
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 14.0, current 27.5, max 27.6
      Supply voltage: min 24.5, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
      Driver 0: position 0, standstill, reads 58965, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 58965, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 58965, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 58968, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 58969, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 58966, writes 14 timeouts 0, SG min/max 0/0
      Date/time: -
      Slowest loop: 0.46ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 408, send timeouts 1039, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 1ms ago
      RX/TX seq numbers: 3754/3754
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c8a8
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 0.04
      Maximum length of RX/TX data transfers: 2696/468
      My config:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 27 2021 21:56:24 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"□□□"                     		; set printer name
      M569 P0.0 S1                                 ; physical drive 0.0 goes S1 forwards
      M569 P0.1 S0                                 ; physical drive 0.1 goes S1 forwards S0 backwards
      M569 P0.2 S0                                 ; physical drive 0.2 goes S1 forwards S0 backwards
      M569 P0.5 S0                                 ; physical drive 0.5 goes S1 forwards S0 backwards
      M584 X0.0 Y0.1 Z0.2 E0.5                     ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X53.33 Y53.33 Z1636.66 E492.40            ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z120.00 E1200.00      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
      M906 X2800 Y2800 Z1600 E1200 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S60                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X□□□Y□□□ Z□□□ S0                       ; set axis maxima
      M574 X1 S1 P"io0.in"                         ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in"                         ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S2 									; added later
      M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F120 R0.5 T3000         ; set Z probe type to bltouch and the dive height + speeds
      											; Note: Try adding a small delay after deploying the probe. The simplest way is to use the R parameter in the M558 command. 0.1 sec should be sufficient.
      											;Remove the ^ in front of the pin name in the M558 command. It's only needed on Duet 2
      G31 P500 X0 Y0 Z5                        	; set Z probe trigger value, offset and trigger height, orgnial G31 P500 X0 Y0 Z2.5
      M557 X0:530 Y0:300 S75:60                   ; define mesh grid
      ; Temp Heatbed
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor (RS-Comp 769-1931, EPCOS NTC Thermistor, 100kΩ = 100000Ω) on pin temp0, orginal T100000 B4138
      M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00  R0.5 D30.0                 ; enable bang-bang mode for the bed heater and set PWM limit, orginal heating rate 2.429, dead time 5.50
      											 ; Zeitkonstante R mindestens doppelt so lang ist wie die Totzeit D
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
      ; Temp Heater Hotend
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor (ed3 Thermistor Cartridge with Semitec 104NT thermistor) on pin temp1
      M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M307 H1 R2.664 C256.6 D8.87 V24.4			 ; PID tune parameters for heater 1
      M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
      M950 F0 C"out7" Q500                         ; create fan 0 on pin out7 and set its frequency, orninal M950 F0 C"out7" Q500
      M106 P0 S1 H-1                             	 ; set fan 1 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                         ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H1 T35                            ; set fan 1 value. Thermostatic control is turned on
      ; Rotating Magnet Filament Monitor
      M591 D0 P3 C"io2.in" S1						; Duet3D rotating magnet sensor (P3) for extruder drive 5 (D0) is connected to io_2
      											; Note:  Sn 0 = disable filament monitoring (default), 1 = enable filament monitoring
      ; Servo 1
      M950 S1 C"io6.out" Q50 						;Enabling Pin6 as GPIO Port 1 on the Expansion Slot for PWM @ 50Hz
      ;M42 P1 S0 									;Switching GPIO Port 0 Off
      ;M42 S1 S0.5  							; set 50% PWM on GPIO Port 1
      M563 P0 D0 H1 F0                             ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      M501                                         ; load saved parameters from non-volatile memory
      wiring :
      I have a 230V AC to 24V DC /15A power supply for the board and a separate supply, 230V AC to 5V DC Mean Well IRM-30-5ST with 6 amps, for the servo. The servo is connected as follows:
      RED, PLUS SERVO -> +V0 Meean Well
      BLACK, MINUS SERVO -> -V0 Mean Well and GND on io.6
      ORANGE, SIGNAL -> io6.out
      I have also tried:
      BLACK, MINUS SERVO -> -V0 Mean Well and Duet 3 Mainboard, Power In GND
      Nothing happens with g-code command M280 P1 S50
      But if I take the servo with a tester and a separate laboratory power supply it moves as it should. It was also tested whether 5v come out of the meanwell power supply. It is ok.
      Datasheet Servo - MG995 Tower-Pro.pdf
      Can someone help me, please?
      DIY-O-Sphereundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @snt
        @snt
        https://forum.duet3d.com/topic/13016/rrf3-and-servo/9?_=1621456861076
        Edit:
        As your board is a 6HC i think you can set the pullup in the config.
        (UTC+1)
          dc42 administrators @snt
          @snt the signal level on io6.out is 3.3V and that might not be enough for your servo. Try using the LASER/VFD output instead, which has 5V signal level.
          I suggest you remove the Q50 parameter from the M950 S1 command. the s1 parameter will cause RRF to set up the frequency correctly.
          • o_lampeundefined
            o_lampe @dc42
            @dc42 said in Help to config Servero MG995 for Duet3 6HC:
            He's not the only user, who confuses frequency with duty cycle. Maybe the wiki could mention that.
            I'd suggest adding a 'start value' for servos or linear actuators in M950.
            What's the current duty cycle of new defined servos? 50% = 1500 us?
            • sntundefined
              snt
              Thank you guys, I will try the solution on the weekend.
              • sntundefined
                snt
                Hello folks,
                what if I want to control 2 servos independently? Do I need a level converter? Can you recommend a level converter to me, please?
                P.S. How can I correct the heading? Servero ->Servo
                  @snt, did using the Laser/VFD output work?
                  PS - I have changed the title.
                  • sntundefined
                    snt
                    I tried out9 (LASER / VFD) and it worked.
                    M92 X53.33 Y53.33 Z1636.66 E492.40            ; set steps per mm, orginal X80.00 Y80.00 Z400.00 E492.40
                    M208 X□□□ Y□□□ Z□□□ S0                       ; set axis maxima
                    M574 Z1 S2 									; nachträglich eingefügt
                    M558 P9 C"io7.in" H5 F120 R0.5 T3000         ; set Z probe type to bltouch and the dive height + speeds, orninal M558 P9 C"^io7.in" H5 F120 T3000
                    											; Try adding a small delay after deploying the probe. The simplest way is to use the R parameter in the M558 command. 0.1 sec should be sufficient.
                    M557 X0:530 Y0:300 S75:60                   ; define mesh grid, orinal X10:190 Y10:190 S20
                    ; Temp Heatbed
                    											; Sn 0 = disable filament monitoring (default), 1 = enable filament monitoring
                    ; Servo 1
                    M950 S1 C"out9" 	 						;Enabling Pin6 as GPIO Port 0 on the Expansion Slot for PWM @ 50Hz
                    ;M42 S0.8 S0.5  							; set 50% PWM on GPIO port 10
                    How can I connect a second servo MG995?
                    cosmowaveundefined 1 Reply Last reply Reply Quote 0
                    • cosmowaveundefined
                      cosmowave @snt
                      @snt if the Duet3 has an heater3 on gpio, you can use:
                      M950 S1 C"exp.heater3"								; assign GPIO port 1 to heater3 on expansion connector, servo mode
                      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
