    Use PrusaSlicer with pspp, temperature management issues
    • charles
      charles last edited by
      Dear friends:
      My E3D Toolchanger is still debugging so far. Currently my machine only has two nozzles. My slicing software is PrusaSlicer 2.3.0, used with pspp, but I encountered a problem during the debugging process:
      Two print heads printing:
      When the No. 0 nozzle is activated, the working temperature of No. 0 nozzle is 200 and the idle temperature of No. 1 nozzle is 170.
      However, when the No. 1 nozzle is activated, the working temperature of the No. 1 nozzle is also 170. The idle temperature of the No. 0 nozzle is 170 normal.
      I checked the parameter settings of my PrusaSlicer, and the working temperature of the print head is 200.
      Please check my configuration parameters:
      May I ask what causes this?
      Looking forward to your reply.
        Phaedrux Moderator @charles last edited by
        @charles said in Use PrusaSlicer with pspp, temperature management issues:
        pspp
        Sorry, what is pspp?
        Can you post your config.g and tool change files? Perhaps a sample of the gcode that is being used so we can see what is happening?
        What firmware version?
        charles 1 Reply Last reply Reply Quote 0
        • charles
          charles @Phaedrux last edited by
          @phaedrux Hello Phaedrux,
          Thank you for your reply.
          pspp is Tool Changer Prusa Slicer post process cript. Its github address is: https://github.com/mkudzia84/toolchanger-pspp/tree/master
          I am currently on a business trip and do not have a configuration file in my hand. I will release it to you when I get home. The firmware version is v3.1.1.
          The firmware I currently use is the configuration file of Nibbels, and the github address is: https://github.com/Nibbels/e3d-toolchanger-config/tree/master
