    Toolboard LC1- v1.1 & Warrenty ?
    • A Former User?
      A Former User
      This post is deleted!
        droftarts administrators @A Former User
        @arnold_r_clark Warranty terms here: https://www.duet3d.com/warranty
        In the case of the LC1 v1.1, it is anticipated that people will make use of the feature to add a switch. If a board failure is demonstrably NOT related to the small amount of work on the board to enable the switch, I think we would generally look favourably on replacement. However, if, for example, it fails due to a short through the switch you added, it would not be covered.
        • A Former User?
          A Former User @droftarts
          • T3P3Tonyundefined
            T3P3Tony administrators @A Former User
            @arnold_r_clark Yes you are correct the warranty policy was written before we shipped a product with an unpopulated footprint designed to allow a customer to add the component.
            I have modified the warranty policy with a specific exception and will look to get the documentation updated as soon as possible.
            In the future if we do this with any other product then I will look to expand the warranty policy to more generic wording.
            www.duet3d.com
            T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
            • T3P3Tonyundefined
              T3P3Tony administrators @T3P3Tony
              @Arnold_R_Clark updated the documentation with some pictures:
              https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board?revisionid=HEAD#Section_Adding_an_IO_3_Switch
              www.duet3d.com
