    BL touch setup help
    • Drak
      Drak last edited by
      I'm having trouble setting up a BL touch on my Duet wifi 2 board and Duex Board expansion. It won't respond to homing in the z axis and crashes into the bed. It also doesn't respond to commands like "M280 P0 S10 and M280 P0 S90 ". When i turn on the printer the BL touch deploys and retracts its trigger and then turns red. Here is the config file. I just want to make sure I set up the probes config portion correctly.
      ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 12 2020 18:09:32 GMT-0500 (Eastern Standard Time)
      M550 P"Jumbo"                                      ; set printer name
      M587 S"Drexel''s_Nest" P"drakasfam95" I10.0.0.36
      M552 S1                                        ; enable network
      M584 X0 Y1:4 Z2:5:7:8 E3                                   ; set drive mapping
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes FORwards
      M569 P3 S0                                         ; physical drive 3 goes forwards
      M569 P5 S0                                         ; physical drive 3 goes forwards
      M569 P7 S0                                         ; physical drive 3 goes forwards
      M569 P8 S0                                         ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z2000.00 E100.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M208 X900 Y900 Z900 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      ; new probe bl touch
      M558 P9 C"^zprobe.in" H5 F100 T2000
      M950 S0 C"duex.pwm1"
      G31 X20 Y0 Z3.3 P25
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M140 H-1                                           ; disable heated bed (overrides default heater mapping)
      M308 S0 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin e0temp
      M950 H0 C"e0heat" T0                               ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S260                                       ; set temperature limit for heater 0 to 260C
      M563 P0 D0 H0 S"Main"                                      ; define tool 1
      G10 P0 X0 Y0 Z0                                    ; set tool 1 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      M501                                               ; load saved parameters from non-volatile memory
      peter247 1 Reply Last reply Reply Quote 0
      • peter247
        peter247 @Drak last edited by
        @drak
        I'm using heater7
        M558 P9 C"^zprobe.in" H2 F100 T8000 A5		; set Z probe type to bltouch and the dive height + speeds
        M950 S0 C"exp.heater7"							; create servo pin 0 for BLTouch
        G31 P500 X 57.5 Y-10.5 Z 1.6                   	; set Z probe trigger value, offset and trigger height 1.7
        M557 X65:275 Y50:290 S30                    	; define mesh grid .. 30 , 60 , 80
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        • PaulHew
          PaulHew last edited by
          Your BLT config looks fine.
          Please post the results of M115 and a picture of the wiring.
          If the probe is not extending and retracting when the commands are issued, I would suspect wiring.
          RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
          Voron 2.4 disassembled..... Waiting for the RailCore Mini....
          Drak 1 Reply Last reply Reply Quote 0
          • Drak
            Drak @PaulHew last edited by
            @paulhew
            M115 results:
            I did solder wires to extend the BL Touch cables but i checked the continuity with a multimeter and everything seemed to be okay.
            Here is a picture of the wiring
            • droftarts
              droftarts administrators @Drak last edited by droftarts
              @drak you have it plugged into duex.pwm5, not duex.pwm1. See the wiring diagram here:
              https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams
              Either plug it in to duex.pwm1, or change config.g to
              M950 S0 C"duex.pwm5"
                Looks like you're on 3.1.1, should probably update the firmware to 3.2.2
                https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2.2
