    UNSOLVED Starting off with a bang
    308
    • Masso
      Masso last edited by
      So happy with the duet 2 WiFi, chugging along this week, rebuilt and rewired my Ender 5 plus, getting to know the firmware, making macro’s, got everything working. What an improvement over Marlin big tree tech headaches. Aaand just before I wanted to close the control box, the BLTouch wires came loose from the expansion port which I have individual crimped DuPont connectors on. Put them back quickly, turned the board back on and BANG…💥……. put the ground and power pins in reverse order…..🙈
      Yup, ofcourse….only blue led on, no more WiFi led flashing. Yippee…
      Call myself Duet Dumbass from now on 🤕
      I’m ordering another one tomorrow,…Dumbass.
      weed2all dc42 2 Replies Last reply Reply Quote 0
      • weed2all
        weed2all @Masso last edited by weed2all
        @masso ouch!
        Probably if changing the 3.3v regulator might be back on track...post a pic of the board!can you identify if something is burned on the board?
        https://www.thingiverse.com/weed2all/designs
        Masso 1 Reply Last reply Reply Quote 0
          dc42 administrators @Masso last edited by
          @masso, we may be able to get your board repaired. Is there any sign of damage to U3, the small square chip? Which country are you in?
          Masso 2 Replies Last reply Reply Quote 0
          • Masso
            Masso @dc42 last edited by
            @dc42 I’m in Holland.
            I’ll inspect the board tomorrow with a fresh pair of eyes.
            I can work on the board myself, got the tools for it, but only basic electronics knowledge.
            I’m a mechanical guy, but I do some electronics repair work for my car projects where possible (basic electronics microscope, rework station and such).
            Thx for the pointers!
            • Masso
              Masso @weed2all last edited by
              @weed2all hope so, I’ll put it under the microscope tomorrow and measure out what components I can understand. 👍
              • Masso
                @dc42 said in Starting off with a bang:
                I shouldn’t be surprised, you guys probably designed and built this board, the U3 chip definitely blew it’s top. I’ve successfully soldered way smaller than that, should be no problem, may the flux be with you….
                I’ll check the forum for chip type and look where I can source one. If that’s all (hopefully) all will be ok and the bang will end up to be “sisser” as we say in Holland 😁
                Thank you for your swift reply and help 👍
                To be continued…
                • Masso
                  Must be a female chip
                  • droftarts
                    droftarts Moderator @Masso last edited by droftarts
                    @masso I've just updated the documentation with voltage regulator part numbers: https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Voltage_regulators_1
                    (Edit: Which has now been edited again to make it correct!)
                    Masso 1 Reply Last reply Reply Quote 1
                    • Masso
                      Masso @Masso last edited by
                      @masso said in Starting off with a bang:
                      No one?
                      Ok,
                      B/c a few volts and it blows it's top....
                      • Masso
                        Masso @droftarts last edited by
                        @droftarts Thank you!
                        You guys sure got your act together....respect👍
                        • Masso
                          Guys, I replaced the chip and it's WORKING!
                          You're the greatest, no more chinese crap boards for me.
                          My next project is going to be a Duet board as well.
                          Thank you 👍
                          • Masso
                            Hi guys, sorry to bother again, after fun printing for a few months, extruder started clogging horribly.
                            Turns out Fan1 (set to extruder as per instructions) is not working correctly anymore.
                            Fan is always on and turning slow instead of from 50C and up.
                            Fan does not power up to speed anymore either.
                            Without load I measure 20.7v immediately after turning on, but judging from slow fan speed upon load the voltage drop is significant, definitely not 20.7v. I tried different fans, same result.
                            What's probably busted? Component TR9 right under Fan1?
                            How can I troubleshoot?
                            Thanks!
                            • T3P3Tony
                              T3P3Tony administrators @Masso last edited by
                              @masso it could be the fan mosfet however this is odd
                              the mosfet switches the ground not the supply, so the V_FAN voltage should be V_IN (or 5V if you have it jumpered that way but that does not sound like the issue)
                              You have tried a different fan - how about a different fan port. As a test you can plug into the always on fan output (just a convenient header to five the FAN VIN and ground.
                              Duet Hardware Designer
                              www.duet3d.com
                              • Masso
                                Masso @T3P3Tony last edited by
                                @t3p3tony Thanks Tony, I think I fried more than the U3 chip when I made a mistake, I'm going to move up to fan2 and reconfigure, if that doesn't work, I'll buy a duet3 5+ mini and install that.
                                This board will then become a hobby board.
