    DWC status monitor only view?
    Duet Web Control
    • CNCModeller
      CNCModeller last edited by
      Having accidentally paused or estopped my printer a couple of times when monitoring a print using DWC on my phone; is there a view for DWC that has no control functions? Just status information?
      Any thoughts would be much appreciated.
      Many thanks
      Barry M
      Custom Large format Polar Printer running Duet 3 Mini +.
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Also Wanhao D5s and D4s, Duet 2/3 control TBD.
      https://www.youtube.com/CNCModellerUK
      https://www.CNCModeller.co.uk
      rkaronde 1 Reply Last reply Reply Quote 0
      • MintyTrebor
        MintyTrebor last edited by
        You could try making your own with BtnCmd. I've tried to make it as mobile friendly as possible. If you do need to add control function buttons, they can be set to be disabled whilst printing or to require confirmation before action. Most of the info panels are available to add as required.
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        • stuartofmt
          stuartofmt last edited by
          Try DUEUI -- You can customize it to what you want.
          https://forum.duet3d.com/category/33/dueui
          Also DuetMonitor may be useful to you.
          https://forum.duet3d.com/topic/23282/duetmonitor
          • rkaronde
            rkaronde @CNCModeller last edited by
            @cncmodeller You can also try the iOS app.
            The app does not allow any actions so should help with the view only aspect.
            https://apps.apple.com/gb/app/duet-app-control/id1548032260
            CNCModeller 1 Reply Last reply Reply Quote 2
            • CNCModeller
              CNCModeller @rkaronde last edited by
              @rkaronde said in DWC status monitor only view?:
              Thanks, I've downloaded the same app for droid, looks good 🙂
