    SD Card 1 only works with M21 P1
    451
    • 3DClonerundefined
      3DCloner
      Hey guys, how are you?
      I'm here with a Duet 2 Wifi MKS and a PanelDue V3 4.3 ". I'm only getting access to the PanelDue SD card (slot 1) when I send the M21 P1 to the console. I have the set connected only to the motherboard's USB, because I'm doing some tests, do you have any influence?
      After sending the command it works normally.
      Thanks in advance!
        jay_s_uk
        @3dcloner what are you trying to do?
        the paneldue SD slot can't be used as the main SD
        3DClonerundefined 1 Reply Last reply Reply Quote 0
        • 3DClonerundefined
          3DCloner @jay_s_uk
          @jay_s_uk I'm trying to run a wifi access gcode with fixed IP, since the whole command doesn't fit on the console, I want to do it this way so my clients don't need to connect the usb cable, just edit the file with the data and run, which by the way worked very well, unfortunately he is not recognizing the card alone, only with the M21 P1.
          And it is not the main SD, the main one is slot 0, on the motherboard ... It is an extra card.
            dc42 administrators @3DCloner
            @3dcloner you could put M21 P1 in config.g if you expect the second SD card to be present at startup time.
            • 3DClonerundefined
              3DCloner @dc42
              @dc42 It works. But any suggestion of what it might be, other than to automatically identify it?
                @3dcloner, RRF does not automatically try to mount the second SD card; however both PanelDue and DWC will try to mount it if you attempt to view files on it.
                • 3DClonerundefined
                  3DCloner @dc42
                  @dc42 Understand. Here the following happens, the upper left button, disappear as in the photo
                  After the M21 P1 it appears ... Could it be a version error in PanelDue?
                    @3dcloner which versions of RRF and PanelDueFirmware are you running?
                    3DClonerundefined 2 Replies Last reply Reply Quote 0
                    • 3DClonerundefined
                      3DCloner @dc42
                      @dc42 RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 and Panel Due firmware version 3.2.11
                      • 3DClonerundefined
                        3DCloner @3DCloner
                        The writing at the top of the photo is just the name of the machine.
                        @dc42 said in SD Card 1 only works with M21 P1:
                        • 3DClonerundefined
                          3DCloner @dc42
                          @dc42 Well, I applied the M21 P1 in config.g, in addition to creating a macro to mount the card, if necessary, if I know anything else that I can solve, I am listening. Otherwise, thank you for the help provided!
