    Software bundle 3.3RC3 now available
    Beta Firmware
    15
    37
    3.0k
    • war4peaceundefined
      war4peace
      FYI:
      [Duet + SBC] RRF updated job.lastFileName as soon as the print started. This confused DSF, causing it not to append the simulated time info to the file when a simulation completed. RRF no longer reports job.lastFileName while a print is in progress.
      This is still not working, I have just simulated a file and the result was not updated in the job list.
      Original topic.
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @war4peace
        I have a Duet2 Ethernet with FW3.3b3.
        When i try to install 3.3rc3 then a error occurs:
        Error: M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          Phaedrux Moderator @cosmowave
          @cosmowave said in Software bundle 3.3RC3 now available:
          Are you uploading that file as well? Make sure it exists in the /firmware/ folder.
            cosmowave @Phaedrux
            @phaedrux
            oh no! I'm so stupid!
            I have to load this file separately...
            I will try it in the evening. Thanks!
              dc42 administrators @war4peace
              @war4peace said in Software bundle 3.3RC3 now available:
              Update tom my previous post.
              I had to connect the Duet 3 6HC to USB and to a laptop, and update the firmware using BOSSA.
              That's odd, the upgrade should have been straightforward.
              war4peaceundefined 1 Reply Last reply Reply Quote 0
                war4peace @dc42
                I expected as much. After almost 1h of it being stuck at 96%, I rebooted the SBC. Then, I had to flash the motherboard firmware through BOSSA.
                I guess the process got stuck while writing the firmware to the motherboard and it got corrupted.
                Nevertheless, it's working now, however file simulation is still broken. Just FYI, maybe you'd like to take a look at it again.
                  @war4peace have you checked that you are definitely running Duet Control Server 3.3.0-rc3?
                    war4peace @dc42
                    Yes sir.
                    M122
                    RepRapFirmware for Duet 3 MB6HC version 3.3RC3 (2021-05-26 12:29:42) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                    Board ID: 08DJM-956BA-NA3TN-6J9FL-3S86T-9TBYS
                    Used output buffers: 1 of 40 (17 max)
                    Static ram: 150784
                    Dynamic ram: 62264 of which 164 recycled
                    Never used RAM 138124, free system stack 126 words
                    Tasks: SBC(ready,5.3%,338) HEAT(delaying,0.0%,295) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,360) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,59) MAIN(running,86.9%,922) IDLE(ready,0.0%,29), total 100.0%
                    Owned mutexes: HTTP(MAIN)
                    Last reset 00:42:39 ago, cause: power up
                    Last software reset at 2021-06-01 14:53, reason: User, GCodes spinning, available RAM 141196, slot 0
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Step timer max interval 133
                    MCU temperature: min 33.0, current 42.7, max 43.0
                    Supply voltage: min 23.9, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/438/438, gc cycles 0
                    Driver 0: position 40000, standstill, reads 9000, writes 20 timeouts 0, SG min/max 0/622
                    Driver 1: position 0, standstill, reads 9000, writes 20 timeouts 0, SG min/max 0/139
                    Driver 2: position 5080, standstill, reads 9001, writes 20 timeouts 0, SG min/max 0/136
                    Driver 3: position 0, standstill, reads 9001, writes 20 timeouts 0, SG min/max 0/956
                    Driver 4: position 0, standstill, reads 9001, writes 20 timeouts 0, SG min/max 0/122
                    Driver 5: position 0, standstill, reads 9006, writes 15 timeouts 0, SG min/max 0/0
                    Date/time: 2021-06-01 15:36:46
                    Slowest loop: 183.00ms; fastest: 0.03ms
                    === Storage ===
                    Free file entries: 10
                    DMs created 125, maxWait 42917ms, bed compensation in use: none, comp offset 0.000
                    === MainDDARing ===
                    Scheduled moves 70, completed moves 70, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                    === AuxDDARing ===
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === CAN ===
                    Messages queued 22964, send timeouts 22961, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 12800/0/0
                    Last cancelled message type 30 dest 127
                    === SBC interface ===
                    State: 4, failed transfers: 0
                    Last transfer: 1ms ago
                    RX/TX seq numbers: 26317/26317
                    SPI underruns 0, overruns 0
                    Number of disconnects: 0, IAP RAM available 0x2c8bc
                    Buffer RX/TX: 0/0-0
                    === Duet Control Server ===
                    Duet Control Server v3.3-rc3
                    Code buffer space: 4096
                    Configured SPI speed: 8000000 Hz
                    Full transfers per second: 34.23
                    Codes per second: 0.06
                    Maximum length of RX/TX data transfers: 2920/848
                    • chrishammundefined
                      chrishamm administrators @war4peace
                      @war4peace Thanks for your feedback. I've updated DSF once again to always wait for the simulated time to be set before trying to write it to the job file, I hope that will fix it once and for all. Likewise I've improved the firmware update code a bit - with my latest code I haven't got a single failed firmware update after approx 30 successive attempts.
                      Duet software engineer
                      garyd9undefined 1 Reply Last reply Reply Quote 0
                      • garyd9undefined
                        garyd9 @chrishamm
                        @chrishamm said in Software bundle 3.3RC3 now available:
                        You aren't superstitious, are you? If I were to say something similar about my own code, it would have most certainly failed on the 31st attempt.
                        "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                          chrishamm administrators @garyd9
                          @garyd9 Just a bit - perhaps I should attempt it again 42 times 😉
                            Off-topic, but 42 is a number worth avoiding in tests. In 7-bit binary, it's a palindrome (and 0x42 is a palindrome in 8-bit binary). A colleague of mine in a previous job was testing a prototype network interface, and for the test he chose to set the 7-bit node address to 42. The board worked. It was later discovered that the wiring of the node ID switches had the bit order reversed.
                            war4peaceundefined 1 Reply Last reply Reply Quote 2
                              war4peace @dc42
                              @dc42 Hence your nickname component 🙂
                              I am turning 42 this year. Oops.
                              @chrishamm Thank you very much for your dedication! I am glad (you know what I mean) to participate to feedback and help make Duet ecosystem better.
                              With that being said, and I know I might be pushing it, but any ballpark estimate (month granularity) for the 3.4 beta/RC? Eager to test new algorithms as well as Toolboard 1.1.
                                @war4peace I hope to have an early 3.4 beta this month for Duet WiFi/Ethernet and for Duet 3/3 Mini without CAN-connected boards.
                                war4peaceundefined peter247undefined 2 Replies Last reply Reply Quote 0
                                  war4peace @dc42
                                  Excellent news! I have a Duet 3 with no connected CAN boards, therefore I could test it.
                                  • peter247undefined
                                    peter247 @dc42
                                    @dc42 is 3.2.2 still the latest stable ?
                                    Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                                    SIamundefined 1 Reply Last reply Reply Quote 0
                                    • SIamundefined
                                      SIam @peter247
                                      @peter247 yes it is
                                      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                      Duet WiFi 1.02 or later + DueX5
                                      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                      Duet WiFi Server: 1.26
                                      Duet Web Control 3.4.0beta4 (2021-09-27)
